Having trouble ripping Buffy the Vampire Slayer - S2 - Disc1
Volkov
#1 Post by Volkov » Fri Jun 10, 2011 9:37 am
I've ripped everything in my collection, but I'm having consistent problems with one certain disc. Disc 6, Season 2 of Buffy. I've tried 3 different copies of the disc (a friend's, and the Library's) in two separate DVD-drives, with the same problem every time.
1 titles saved, 1 failed
Debug log started at Fri Jun 10 09:05:45 2011 , written by MakeMKV v1.6.10 win(x86-release)
001005:0000 MakeMKV v1.6.10 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Volkov/MakeMKV_log.txt
003028:0000 Title #0 was added (15 cell(s), 0:42:15)
003028:0000 Title #1 was added (15 cell(s), 0:42:10)
003028:0000 Title #2 was added (1 cell(s), 0:13:46)
003028:0000 Title #3 was added (1 cell(s), 0:29:26)
003028:0000 Title #4 was added (1 cell(s), 0:20:18)
003028:0000 Title #5 was added (1 cell(s), 0:00:46)
003028:0000 Title #6 was added (1 cell(s), 0:02:39)
003028:0000 Title #7 was added (1 cell(s), 0:00:52)
003028:0000 Title #8 was added (1 cell(s), 0:00:52)
003025:0000 Title #9 has length of 7 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Title skip vts=2 pgcn=1 hash=AA92E95FBBC3498C
Title skip vts=2 pgcn=2 hash=A48857BF101A0292
003025:0000 Title #12 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #13 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #14 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #15 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
Title skip vts=2 pgcn=7 hash=D2EB084BCD0069BF
Title skip vts=2 pgcn=8 hash=3540CAD4EF1AF2A9
003025:0000 Title #18 has length of 6 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #19 has length of 6 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #20 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #21 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #22 has length of 4 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #23 has length of 3 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #24 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #25 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #26 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #27 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #28 has length of 4 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #29 has length of 3 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #30 has length of 5 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #31 has length of 4 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #32 has length of 3 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #33 has length of 3 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #34 has length of 4 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #35 has length of 3 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #36 has length of 2 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #37 has length of 2 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #38 has length of 4 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003025:0000 Title #39 has length of 3 seconds which is less than minimum title length of 10 seconds and was therefore skipped
003030:0000 Subtitle stream #1 is identical to stream #0 and was skipped
003030:0000 Subtitle stream #2 is identical to stream #0 and was skipped
005014:0000 Saving 2 titles into directory U:/BUFFY_SEASON2_DISC6
001003:0020 DEBUG: Code 181 at 0&8#ut~+\f[<#QlS9!*!~G:213129823
001003:0020 DEBUG: Code 1370 at m:&8?QMLXwacca:6'O7pb:121264786
001003:0020 DEBUG: Code 2025 at m:&8?QMLXwacca:6'O7pb:121264786
001003:0020 DEBUG: Code 14 at 0&8#ut~+\f[<#QlS9!*!~G:213129823
001003:0020 DEBUG: Code 1470 at m:&8?QMLXwacca:6'O7pb:121264786
001003:0020 DEBUG: Code 58 at neBG8dAFG6$j#7"dIIR:29398254
RH=ZeNo1ks0rw3Ecx1+Ng8MOjo6ODjs6rjgow0KeUi477ODAxUELaR4aeVxaEktLkqS1hJYkSUJLS0uSJC1JS/IX+LTe39Pv1av39/N7fx8mh8FDJdkGiJW5goh9p+WX/DArrm2EJWWYhHn541ZYEFcbrykTmIIV+WgA4uJCM2wok7NMQr6mHdbFdMB2mT0kT2BTPmg+6bq1wK7mhGOQks9bZkdcND5QxrsIe/LeLtgX99t/M8qEVuFQPtELafF8D5wqU2VzjuSTfXAsruuHc3UeuoOsfMjmnIkrja80J2GdL+T9bXDp8jbz1p3hMlzLH5q/EdcbPyhzPgf3bm035MSXNrOgjG8G8vKDtpdHcck6v6gzZ/DkzmQAnsU+O593zQnavb/Kx+2u38SZTvhUph
and after that it has scrambled things like that for 800KB or so...
Re: Having trouble ripping Buffy the Vampire Slayer - S2 - D
#2 Post by mike admin » Fri Jun 10, 2011 2:21 pm
Please send the full log and IFO files per instructions at http://www.makemkv.com/faq/item/8/catid/6
Navvie
#3 Post by Navvie » Fri Jun 10, 2011 8:10 pm
I ripped all the BTVS DVDs without error using, er... an older 1.6.x version of MakeMKV. In Fact, BTVS was one of the first TV series I ripped.
My DVDs were Region 2 and the first release using the plastic cases, rather than the paper fold out cases.
Registered user
Linux / Windows 10
Asus BW-16D1HT 3.10MK (disc exploded, taking out my second BW-16D1HT)
Asus BC-12D2HT 3.11MK
LG BH16NS40 flashed to WH16NS60 1.03
LG GGC-H20L 1.03
Pioneer BDR-205 GENE
Volkov
#4 Post by Volkov » Sat Jun 11, 2011 5:33 am
I've tried three discs, all from different style collection box sets. All region 4. Sent email.
Volkov
#5 Post by Volkov » Thu Jul 07, 2011 7:44 am
Sorry for bumping, but it's been about a month since i sent the email as per instructions. I was wondering what actually happened from then?
thank you
tenfour
#6 Post by tenfour » Wed Aug 10, 2011 3:06 am
Navvie wrote:I ripped all the BTVS DVDs without error using, er... an older 1.6.x version of MakeMKV. In Fact, BTVS was one of the first TV series I ripped.
I have these discs and get the exact same error as the OP on the same disc using 1.6.12.
#7 Post by mike admin » Sat Aug 13, 2011 2:59 pm
After all it looks like a structure protection that MakeMKV can't handle. There will be no fix in 1.6.14, but 1.6.14 will have a new logging option that should pinpoint the issue. With new debug log from 1.6.14 this should be fixed very shortly, maybe even as workaround in 1.6.14 . For now you can only wait, sorry.
samukas
#8 Post by samukas » Thu Sep 08, 2011 11:47 am
So, I'm having this problem as well with the same disk.
I believe now that 1.6.14 is out, there are more logging tools, could anyone please tell me what should I do and send so that this problem can be looked at?
Is it the same as these instructions: http://www.makemkv.com/faq/item/8/catid/6 ?
Or something changed with this new version?
