UNSCTrafalgar wrote:
Wed Jul 19, 2023 8:48 pm
all the tools are available on the dovi script GD link. download , extract and run the bat file.
Still having the EAE timeout issue. I don’t think it’s a case of a missing easyaudioencoder.exe or Plex file/folder. I’ve reinstalled the tools pack and script, made sure all tools are accounted for, and encountered the same issue converting TrueHD 7.1 to DD+ across macOS (running Parallels) and a normal Windows PC. Any thoughts on what this error could be? Thanks again for being so responsive.
No idea, it's working fine on my end with all the workflows that can encode 7.1 EC3.
In the worst-case scenario, you can always disable 7.1 encoding (line 32 set encode_7.1=NO)
lolipeid47
Post by lolipeid47 »
Gamut script seems to need some debugging, Heatmap working but not the gamut one
lolipeid47 wrote:
Wed Jul 19, 2023 10:22 pm
pip install scikit-image
lolipeid47
RESET_9999 wrote:
Wed Jul 19, 2023 10:23 pm
thank you :mrgreen:
fransalas
Post by fransalas »
When I execute the command 3-2 after giving the appropriate settings, this message appears
Do the borders detection manually.
I'll check out why ''auto'' doesn't work later.
legosoff
Post by legosoff »
Hi, RESET_9999.
1) Mode 7/1/1 iPhone, iPad subtitles don't work, ffmpeg there are subtitles.
2) Mode 7/1/1 iPhone, iPad Dolby Vision don't work, he was just reading HDR10 https://radikal.host/i/FtgBco , other test_demo https://radikal.host/i/Ftgbsd
Cr4z33
Post by Cr4z33 »
I've remuxed a DV title with MKVtoolnix, but when it comes to MakeMKV I keep getting errors.
And by the way SAME errors with both DV MP4/MKV sources.
Is there really nothing I can do about it? :cry:
MakeMKV v1.17.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Cr4z33/MakeMKV_log.txt
Opening files on harddrive at Z:/***/***.mkv
Saving 1 titles into directory Y:/2160p/***
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 0 at P!"D9mkbBYey!WCL"e9n:29397081
DEBUG: Code 0 at Ja:%,=w1-Hvtlno[h?Ff:29398208
The source file 'Z:/***/***.mkv' is corrupt or invalid at offset 14345576448, attempting to work around
DEBUG: Code 0 at P!"D9mkbBYey!WCL"e9n:121265453
DEBUG: Code 0 at Ja:%,=w1-Hvtlno[h?Ff:213135021
DEBUG: Code 0 at |03L4Qet`E.eCrMo,`Zs':213137068
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29394022
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29404878
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29405384
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29403383
DEBUG: Code 0 at _m/rhT44"V1.WQmL:213132537
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121264464
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121263912
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):213130145
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 0 to file Y:/2160p/***/***_t00.mkv
0 titles saved, 1 failed
Nvidia Shield TV Pro -> DENON AVR-X2200W -> LG OLED65GX6
legosoff wrote:
Sat Jul 22, 2023 7:15 am
Hi, RESET_9999.
Well, I don't know. I changed 7-1-1 a while ago(HEV1 to HVC1) because the appleTV now natively supports Profile 8 and HEV1 didn't work.
I guess that broke support on other devices?
legosoff
Post by legosoff »
RESET_9999 wrote:
Sat Jul 22, 2023 12:52 pm
Hi, RESET_9999.
[*Dolby Vision works]
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.10, BL+RPU, HLG compatible
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Duration : 4 s 485 ms
Bit rate : 53.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Rotation : 90°
Frame rate mode : Variable
Frame rate : 60.000 FPS
Minimum frame rate : 54.545 FPS
Maximum frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.107
Stream size : 28.4 MiB (100%)
Title : Core Media Video
Encoded date : 2023-07-10 14:13:37 UTC
Tagged date : 2023-07-10 14:13:43 UTC
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : HLG
Metas : 3,4,5
Codec configuration box : hvcC+dvvC
[*Dolby Vision no]
Video
Format : HEVC
Format profile : Main 10@L5@Main
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : hvc1
Duration : 1 h 36 min
Bit rate : 24.3 Mb/s
Maximum bit rate : 34.8 Mb/s
Height : 1 608 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.164
Stream size : 16.4 GiB (94%)
Title : UPGRADE_2018_UHD_HDR10_DV_ENCODER | CinemaHD
Encoded date : 2023-07-21 13:55:06 UTC
Tagged date : 2023-07-21 13:55:30 UTC
Transfer characteristics : PQ
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light : 280 cd/m2
mdhd_Duration : 5784070
I have already understood when when HDR10 compatible / SMPTE ST 2086 does not show Dolby Vision. HLG compatible that is , it shows Dolby Vision
It's hard for me to tell why because I dont have Apple devices but someone(@ragico) who tested the appleTV latest firmware said that 7-1-1 now produces profile-8 ( HDR10 base layer) that works on AppleTV native player.
Are you using apple native player?
legosoff
Post by legosoff »
RESET_9999 wrote:
Sat Jul 22, 2023 1:49 pm
appleTV no, only iPhone 13 and 14 Pro Max.
you could try the older version(1.7.4) of the script maybe.
legosoff
Post by legosoff »
RESET_9999 wrote:
Sat Jul 22, 2023 1:58 pm
version(1.7.4) I have done and received see dvh1, HDR10, Dolby Vision no. I seem to have something to update the iPhone and stopped.
Carefully, RPU 8.1+HDR10 Dolby Vision no. RPU 8.1+HLG Dolby Vision yes.
Do you have test demo video RPU 8.1+HDR10? Please send me a link.
fransalas
Post by fransalas »
The previous error was solved but these messages keep coming out
