This Ali Exp drive works perfectly with MAKMKV DAV & BD
blue19
Post by blue19 »
Hi just posting a Ali Ex link to an ex drive I got from Ali Express works great with MAKEMKV both types of disk.
https://www.aliexpress.com/item/1005004 ... 1802C86QEb
Just don't for get to set your "region" in Drive properties in Windows ! its not "Forever multi region " you only get 5 changes.
I'm using Win 11 latest version.
Re: This Ali Exp drive works perfectly with MAKMKV DAV & BD
That doesn't sound "perfect" for MakeMKV if it needs to have the region set for anything. MakeMKV is able to make most drives ignore region coding.
