The easiest way is to use SDFtool Flasher and follow these steps.Starkiller-1994 wrote: ↑Tue Jul 18, 2023 12:14 amI am trying to do this process for BP50NB40. In the section it mean BP50NB40 to > BP50NB40-NB50-1.03MK and ...> BP50NB40-NB50-1.03MK with enc. Where do i find the with enc and the BP50NB40-NB50-1.03MK with bootloader/full flash as well.
1. Flash the drive to BP50NB40 (NB50) 1.03-MK.
Now for the crossflash:
2. Select the RECOVERY option and in the pop up, select the BP50NB40 (NB50) 1.03-MK firmware that you just flashed.
3. Select the BP60NB10 1.00-MK or BU40N 1.00 firmware that you want to use in the normal drop box.
4. Click START
