lolipeid47
#8566 Post by lolipeid47 » Wed Jul 19, 2023 11:02 pm
RESET_9999 wrote: Wed Jul 19, 2023 10:23 pm
lolipeid47 wrote: Wed Jul 19, 2023 10:22 pm Gamut script seems to need some debugging, Heatmap working but not the gamut one
pip install scikit-image
thank you :mrgreen:
fransalas
#8567 Post by fransalas » Fri Jul 21, 2023 9:37 am
When I execute the command 3-2 after giving the appropriate settings, this message appears
#8568 Post by RESET_9999 » Fri Jul 21, 2023 11:26 am
Do the borders detection manually.
I'll check out why ''auto'' doesn't work later.
legosoff
#8569 Post by legosoff » Sat Jul 22, 2023 7:15 am
Hi, RESET_9999.
1) Mode 7/1/1 iPhone, iPad subtitles don't work, ffmpeg there are subtitles.
2) Mode 7/1/1 iPhone, iPad Dolby Vision don't work, he was just reading HDR10 https://radikal.host/i/FtgBco , other test_demo https://radikal.host/i/Ftgbsd
Cr4z33
#8570 Post by Cr4z33 » Sat Jul 22, 2023 12:32 pm
I've remuxed a DV title with MKVtoolnix, but when it comes to MakeMKV I keep getting errors.
And by the way SAME errors with both DV MP4/MKV sources.
Is there really nothing I can do about it? :cry:
MakeMKV v1.17.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Cr4z33/MakeMKV_log.txt
Opening files on harddrive at Z:/***/***.mkv
Saving 1 titles into directory Y:/2160p/***
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 0 at P!"D9mkbBYey!WCL"e9n:29397081
DEBUG: Code 0 at Ja:%,=w1-Hvtlno[h?Ff:29398208
The source file 'Z:/***/***.mkv' is corrupt or invalid at offset 14345576448, attempting to work around
DEBUG: Code 0 at P!"D9mkbBYey!WCL"e9n:121265453
DEBUG: Code 0 at Ja:%,=w1-Hvtlno[h?Ff:213135021
DEBUG: Code 0 at |03L4Qet`E.eCrMo,`Zs':213137068
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29394022
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29404878
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29405384
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29403383
DEBUG: Code 0 at _m/rhT44"V1.WQmL:213132537
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121264464
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121263912
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):213130145
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 0 to file Y:/2160p/***/***_t00.mkv
0 titles saved, 1 failed
Nvidia Shield TV Pro -> DENON AVR-X2200W -> LG OLED65GX6
#8571 Post by RESET_9999 » Sat Jul 22, 2023 12:52 pm
legosoff wrote: Sat Jul 22, 2023 7:15 am Hi, RESET_9999.
Well, I don't know. I changed 7-1-1 a while ago(HEV1 to HVC1) because the appleTV now natively supports Profile 8 and HEV1 didn't work.
I guess that broke support on other devices?
legosoff
#8572 Post by legosoff » Sat Jul 22, 2023 1:38 pm
RESET_9999 wrote: Sat Jul 22, 2023 12:52 pm
[*Dolby Vision works]
Video
Format : HEVC
HDR format : Dolby Vision, Version 1.0, dvhe.08.10, BL+RPU, HLG compatible
Codec ID : hvc1
Codec ID/Info : High Efficiency Video Coding
Duration : 4 s 485 ms
Bit rate : 53.1 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Rotation : 90°
Frame rate mode : Variable
Frame rate : 60.000 FPS
Minimum frame rate : 54.545 FPS
Maximum frame rate : 60.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.107
Stream size : 28.4 MiB (100%)
Title : Core Media Video
Encoded date : 2023-07-10 14:13:37 UTC
Tagged date : 2023-07-10 14:13:43 UTC
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : HLG
Metas : 3,4,5
Codec configuration box : hvcC+dvvC
[*Dolby Vision no]
Video
Format : HEVC
Format profile : Main 10@L5@Main
HDR format : Dolby Vision, Version 1.0, dvhe.08.06, BL+RPU, HDR10 compatible / SMPTE ST 2086, HDR10 compatible
Codec ID : hvc1
Duration : 1 h 36 min
Bit rate : 24.3 Mb/s
Maximum bit rate : 34.8 Mb/s
Height : 1 608 pixels
Display aspect ratio : 2.40:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.164
Stream size : 16.4 GiB (94%)
Title : UPGRADE_2018_UHD_HDR10_DV_ENCODER | CinemaHD
Encoded date : 2023-07-21 13:55:06 UTC
Tagged date : 2023-07-21 13:55:30 UTC
Transfer characteristics : PQ
Mastering display color pri : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light : 280 cd/m2
mdhd_Duration : 5784070
I have already understood when when HDR10 compatible / SMPTE ST 2086 does not show Dolby Vision. HLG compatible that is , it shows Dolby Vision
#8573 Post by RESET_9999 » Sat Jul 22, 2023 1:49 pm
It's hard for me to tell why because I dont have Apple devices but someone(@ragico) who tested the appleTV latest firmware said that 7-1-1 now produces profile-8 ( HDR10 base layer) that works on AppleTV native player.
Are you using apple native player?
legosoff
#8574 Post by legosoff » Sat Jul 22, 2023 1:53 pm
RESET_9999 wrote: Sat Jul 22, 2023 1:49 pm It's hard for me to tell why because I dont have Apple devices but someone(@ragico) who tested the appleTV latest firmware said that 7-1-1 now produces profile-8 ( HDR10 base layer) that works on AppleTV native player.
appleTV no, only iPhone 13 and 14 Pro Max.
#8575 Post by RESET_9999 » Sat Jul 22, 2023 1:58 pm
you could try the older version(1.7.4) of the script maybe.
legosoff
#8576 Post by legosoff » Sat Jul 22, 2023 3:07 pm
RESET_9999 wrote: Sat Jul 22, 2023 1:58 pm you could try the older version(1.7.4) of the script maybe.
version(1.7.4) I have done and received see dvh1, HDR10, Dolby Vision no. I seem to have something to update the iPhone and stopped.
Carefully, RPU 8.1+HDR10 Dolby Vision no. RPU 8.1+HLG Dolby Vision yes.
Do you have test demo video RPU 8.1+HDR10? Please send me a link.
fransalas
#8577 Post by fransalas » Sat Jul 22, 2023 11:58 pm
The previous error was solved but these messages keep coming out
Cr4z33
#8578 Post by Cr4z33 » Sun Jul 23, 2023 6:24 am
Cr4z33 wrote: Sat Jul 22, 2023 12:32 pm I've remuxed a DV title with MKVtoolnix, but when it comes to MakeMKV I keep getting errors.
Anybody that can please help me?
qwertiio
#8579 Post by qwertiio » Sun Jul 23, 2023 6:56 am
RESET_9999 wrote: Sun Jul 16, 2023 5:40 pm DoVi_Scripts_1.8.9.1.beta
(3-1) can now generate DV with the Dolby cmv4.0 algo without the need for Davinci Resolve. It can also work without an nvidia GPU.
It can generate frame-by-frame long-play or shot-by-shot metadata. I haven't compared the scene cut detection algo I'm using with the one in Resolve yet.
needed exe (metafier and cm_analyze) can be found here: https://customer.dolby.com/content-crea ... tools-v530
fransalas wrote: Fri Jul 14, 2023 8:24 am Some explanatory manual of how to perform the process with DaVinci
there's an SDR to HDR template in my script tutorial folder that will convert gamma 2.4 to PQ.
Then you have to play with the HDR settings in resolve.
Phantomas wrote: Sat Jul 15, 2023 6:12 am Hello! Please tell me with what software I can change the fps of the Atmos track?
DEE but you should change the video fps instead.
https://professional.dolby.com/product/ ... ng-engine/
Lapihin_A wrote: Sat Jul 15, 2023 5:18 pm Hi RESET_9999! I know how, my question is exactly - Will the HDR10+ metadata work correctly IF! the two videos are different frame sizes? Is there any parameter similar to Level 5 in HDR10+ metadata as in Dolby Vision?
if the frame order is the same, I guess so. I don't know much about hdr10plus
fransalas wrote: Sun Jul 16, 2023 3:55 pm There would be some possibility to add in your tool in the 6-9 the possibility to add or modify HDR metadata such as Luminance monitor mastering, Light level maximum content and in maximum medium frame .. thanks is just to know if you could
6-9 already takes the metadata from the source rpu.
In mode 3-1, I got this "invalid Mastering Display index specified (ID:1000)" error in some video files, is it possible to manually choosing preset mastering displays or is there any workaround for this error????
I'm using this file as an example.
https://mega.nz/file/aOIj3RgY#9YSI8ik27 ... DVd7ga_vjc
fransalas
#8580 Post by fransalas » Sun Jul 23, 2023 10:36 am
I have deleted it because in its update it has been resolved
