External Hard Drives
Re: External Hard Drives
Post by Woodstock » Wed Jul 19, 2023 4:29 pm
If the TV has a network connection, using a server for the movies is a good way to go. I currently use Synology servers on my network, and pull things up via the TV's network connection.
Using a disk plugged directly into the TV is one way to do things, but it limits you because you have to move the drive around when you want to add or change what's available.
jinx100
Post by jinx100 » Wed Jul 19, 2023 7:58 pm
Woodstock - see viewtopic.php?f=1&t=31247
A case of spam by revision?
Post by Woodstock » Wed Jul 19, 2023 11:43 pm
I check them as best I can, but... yes, this is someone spamming to put attack code into their messages.
I've zapped the person AND the original posting. I try to catch them, but sometimes they're here before they get caught by other sites. Thanks!
