Two video files?
sail81
Two video files?
Post by sail81 »
I've ripped this Blu-ray movie, Journey to The Centre of the Earth, but when I open it in makemkv, there seems to the option to remove the video file, normally this isn't the case and for this movie, there are two video files.
Why is this?
Re: Two video files?
If there are more than one "cut", they often put them on the disk as separate files. If there is "wide screen" vs. "television screen" versions, you'll have more than one file.
Ezatoka
Post by Ezatoka »
Is this a 3D movie? Then you can deselect the "3D" part so to speak.
Example:
(https://i.imgur.com/5VQ9yZi.png if the picture doesn't load)
