Vellichroma9
Post by Vellichroma9 »
Hi guys. I wanted to reach out regarding an error message I encountered while attempting to use the "HDR10(madVR) or HDR10plus to DoVi maker" tool to create a DoVi (Dolby Vision) file from an HDR10 source (SMPTE ST 2086, HDR10 compatible).
I am using the "DoVi_Scripts_1.8.6_MKV" batch script and upon executing the process, I received the following error message:
Parsing RPU file...
Error: The system cannot find the file specified. (os error 2)
MDL.max: 1000
MDL.min: 50
Maxcll: 1000
Maxfall: 998
injecting RPU-L6-L5.bin ...
Parsing RPU file...
mkvmerge v77.0 ('Elemental') 64-bit
Error: The type of file '\Mrs. Davis S01E01_P8_DoVi.hevc' could not be recognized.
Parsing RPU file...
Parsing RPU file...
"The script has completed"
I would appreciate any help in troubleshooting this issue. Thanks in advanced for any responses.
yossSP wrote:
Tue Jul 18, 2023 11:56 pm
Hi RESET_1999, what do you mean when you say that TV-LED now works in Chromecast with Google TV but it's fake?
Thanks for your support :)
meaning it's still the player doing the RPU processing.
https://www.youtube.com/watch?v=z8sgHR78Rdw
Vellichroma9 wrote:
Wed Jul 19, 2023 12:50 am
Did you install madvr / lavfilters?
https://www.videohelp.com/software/LAV-Filters
https://www.videohelp.com/software/madVR
Vellichroma9
RESET_9999 wrote:
Wed Jul 19, 2023 1:29 am
Hi RESET. Thanks for the reply. Yes, I have installed the latest version of madVR, however i cannot find the executable named madMeasureHDR.exe. As for the LAV-Filters, I also have them installed, however I am not sure If I am meant to place it in the tools folder.
Vellichroma9 wrote:
Wed Jul 19, 2023 1:51 pm
madMeasureHDR.exe is already included in the tool pack. As for lav filters, you just have to install it, and no need to be in the tools folder.
Anyway, you will get better DV generation if you use the new Dolby workflow in 3-1 (latest version of the script)
UNSCTrafalgar
Post by UNSCTrafalgar »
all the tools are available on the dovi script GD link. download , extract and run the bat file.
Still having the EAE timeout issue. I don’t think it’s a case of a missing easyaudioencoder.exe or Plex file/folder. I’ve reinstalled the tools pack and script, made sure all tools are accounted for, and encountered the same issue converting TrueHD 7.1 to DD+ across macOS (running Parallels) and a normal Windows PC. Any thoughts on what this error could be? Thanks again for being so responsive.
Amateur enthusiast 8)
LG E8 55” ——-> Vizio M512A-H6
Vellichroma9
RESET_9999 wrote:
Wed Jul 19, 2023 2:27 pm
Thanks for the help. Using the latest script solved it! :D
UNSCTrafalgar wrote:
Wed Jul 19, 2023 8:48 pm
No idea, it's working fine on my end with all the workflows that can encode 7.1 EC3.
In the worst-case scenario, you can always disable 7.1 encoding (line 32 set encode_7.1=NO)
lolipeid47
Post by lolipeid47 »
Gamut script seems to need some debugging, Heatmap working but not the gamut one
lolipeid47 wrote:
Wed Jul 19, 2023 10:22 pm
pip install scikit-image
lolipeid47
RESET_9999 wrote:
Wed Jul 19, 2023 10:23 pm
thank you :mrgreen:
fransalas
Post by fransalas »
When I execute the command 3-2 after giving the appropriate settings, this message appears
Do the borders detection manually.
I'll check out why ''auto'' doesn't work later.
legosoff
Post by legosoff »
Hi, RESET_9999.
1) Mode 7/1/1 iPhone, iPad subtitles don't work, ffmpeg there are subtitles.
2) Mode 7/1/1 iPhone, iPad Dolby Vision don't work, he was just reading HDR10 https://radikal.host/i/FtgBco , other test_demo https://radikal.host/i/Ftgbsd
Cr4z33
Post by Cr4z33 »
I've remuxed a DV title with MKVtoolnix, but when it comes to MakeMKV I keep getting errors.
And by the way SAME errors with both DV MP4/MKV sources.
Is there really nothing I can do about it? :cry:
MakeMKV v1.17.4 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Cr4z33/MakeMKV_log.txt
Opening files on harddrive at Z:/***/***.mkv
Saving 1 titles into directory Y:/2160p/***
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
DEBUG: Code 0 at P!"D9mkbBYey!WCL"e9n:29397081
DEBUG: Code 0 at Ja:%,=w1-Hvtlno[h?Ff:29398208
The source file 'Z:/***/***.mkv' is corrupt or invalid at offset 14345576448, attempting to work around
DEBUG: Code 0 at P!"D9mkbBYey!WCL"e9n:121265453
DEBUG: Code 0 at Ja:%,=w1-Hvtlno[h?Ff:213135021
DEBUG: Code 0 at |03L4Qet`E.eCrMo,`Zs':213137068
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29394022
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29404878
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29405384
DEBUG: Code 0 at C2qeZ(}9UaJ/_9ed[EW}:29403383
DEBUG: Code 0 at _m/rhT44"V1.WQmL:213132537
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121264464
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):121263912
DEBUG: Code 0 at S+CKH[[Cjt"K.94+):213130145
LIBMKV_TRACE: Exception: Error in p->FetchFrames(2,true)
Failed to save title 0 to file Y:/2160p/***/***_t00.mkv
0 titles saved, 1 failed
Nvidia Shield TV Pro -> DENON AVR-X2200W -> LG OLED65GX6
legosoff wrote:
Sat Jul 22, 2023 7:15 am
Hi, RESET_9999.
Well, I don't know. I changed 7-1-1 a while ago(HEV1 to HVC1) because the appleTV now natively supports Profile 8 and HEV1 didn't work.
I guess that broke support on other devices?
