Very low audio
Ampster
Very low audio
#1 Post by Ampster » Mon Aug 10, 2009 10:53 am
I've managed to make a mkv file with the superb MakeMKV software but I have a problem and it is the volume. It's very low. The 6 channel movie sound is low but the 2 channel commentary track is perfect.
How do I fix this?
Re: Very low audio
#2 Post by mike admin » Tue Aug 11, 2009 8:48 am
What player are you using to play? Did you try VLC?
Wasabi
Re: Very low audio
#3 Post by Wasabi » Mon Aug 17, 2009 11:13 pm
This is normal. I believe it's to accommodate the wider dynamic range of the 5.1 audio track.
Your software might have an option to compensate. I know in KMPlayer there is a setting called "Pre-amplify AC3/DTS Volume to proper level".
