Help!
vlopez4574
Help!
Post by vlopez4574 » Mon Jul 17, 2023 11:57 pm
Just got a flashed Asus bw-16d1ht, but every time I try to open a 4K disc I get this message in the attached pic. Please help. I have no idea what to do. I attached the info in the pic.
Re: Help!
Post by Billycar11 » Tue Jul 18, 2023 12:14 am
pic is missing
vlopez4574
Re: Help!
Post by vlopez4574 » Tue Jul 18, 2023 12:26 am
Thanks for the heads up. The pic should be attached now.
Re: Help!
Post by Billycar11 » Tue Jul 18, 2023 12:55 am
nope
just upload to something like imgur then link it here
vlopez4574
Re: Help!
Post by vlopez4574 » Tue Jul 18, 2023 1:00 am
This is what it said:
"Downloading latest SDF to /Users/
Library/MakeMKV
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v06.3 id=OFA242DD4DOB)
Downloading latest HK to /Users/.
Library/MakeMKV
Saved AACS dump file as /Users
/Library/MakeMKV/MKB20_V68_MARVEL'S_AVENGERS-_ENDGAME_4EDD.tgz
Failed to open disc"
Here's the Drive Info:
Firmware version: 3.10
Re: Help!
Post by Billycar11 » Tue Jul 18, 2023 1:12 am
Library/MakeMKV
Library/MakeMKV
your issue is your dsn/firewall/isp is blocking getting keys
try changing your dns
try using a vpn
if your a customer of mine email me i can provide hk updates.
vlopez4574
Re: Help!
Post by vlopez4574 » Tue Jul 18, 2023 1:31 am
My firewall is off. So what should I check next?
Re: Help!
Post by Billycar11 » Tue Jul 18, 2023 1:35 am
already told you all the relevant steps
you could also try delete your privatedata.tar some have said that helps it work again
Re: Help!
Post by MartyMcNuts » Tue Jul 18, 2023 5:51 am
Library/MakeMKV
Library/MakeMKV
Have you actually ticked the box in MakeMKV preferences to allow internet access? This must be enabled so MakeMKV can download the UHD hashed keys.
vlopez4574
Re: Help!
Post by vlopez4574 » Tue Jul 18, 2023 9:49 am
I did. I have a free security software running tho. Could that be blocking it?
Re: Help!
Post by Woodstock » Tue Jul 18, 2023 1:31 pm
Quite probably. If your DNS is set to use Cloudflare, for example, it might not resolve the host that is used for keys, because it uses a "dangerous host name".
I use my own DNS, so I rarely see an issue, but a lot of people use "safe" DNS resolution services, and they might not resolve the domain.
