Help!
vlopez4574
Help!
Just got a flashed Asus bw-16d1ht, but every time I try to open a 4K disc I get this message in the attached pic. Please help. I have no idea what to do. I attached the info in the pic.
Re: Help!
pic is missing
vlopez4574
Re: Help!
Thanks for the heads up. The pic should be attached now.
Re: Help!
nopevlopez4574 wrote: Tue Jul 18, 2023 12:26 am Thanks for the heads up. The pic should be attached now.
just upload to something like imgur then link it here
vlopez4574
Re: Help!
This is what it said:
"Downloading latest SDF to /Users/
Library/MakeMKV
Automatic SDF downloading is disabled or failed.
Using LibreDrive mode (v06.3 id=OFA242DD4DOB)
Downloading latest HK to /Users/.
Library/MakeMKV
Saved AACS dump file as /Users
/Library/MakeMKV/MKB20_V68_MARVEL'S_AVENGERS-_ENDGAME_4EDD.tgz
Failed to open disc"
Here's the Drive Info:
Firmware version: 3.10
Library/MakeMKV
Library/MakeMKV
Re: Help!
your issue is your dsn/firewall/isp is blocking getting keysvlopez4574 wrote: Tue Jul 18, 2023 1:00 am This is what it said:
Library/MakeMKV
Library/MakeMKV
try changing your dns
try using a vpn
if your a customer of mine email me i can provide hk updates.
vlopez4574
Re: Help!
My firewall is off. So what should I check next?
Re: Help!
already told you all the relevant steps
you could also try delete your privatedata.tar some have said that helps it work again
Re: Help!
Have you actually ticked the box in MakeMKV preferences to allow internet access? This must be enabled so MakeMKV can download the UHD hashed keys.vlopez4574 wrote: Tue Jul 18, 2023 1:00 am This is what it said:
Library/MakeMKV
Library/MakeMKV
vlopez4574
Re: Help!
I did. I have a free security software running tho. Could that be blocking it?
Re: Help!
Quite probably. If your DNS is set to use Cloudflare, for example, it might not resolve the host that is used for keys, because it uses a "dangerous host name".Could that be blocking it?
I use my own DNS, so I rarely see an issue, but a lot of people use "safe" DNS resolution services, and they might not resolve the domain.
