Looking for a free way to backup a X project DRM dvd to an ISO. All methods I could find included using paid software which isn't in my budget. Wondering if MakeMKV will ever get support for this, or if there is other free software I could use?
Thank you
Back up X Project DRM DVD
jimson8
Re: Back up X Project DRM DVD
MakeMKV isn't likely to have "DVD to ISO" support, but I've simply used the operating system''s copy command to copy the disk to an ISO.
flojo
Which command for which OS and is it a "pure" non-hybrid UDF image? I'm looking for a way to create a ~88GB UHD.iso (but not to burn).Woodstock wrote: Mon Jul 17, 2023 4:44 pm MakeMKV isn't likely to have "DVD to ISO" support, but I've simply used the operating system''s copy command to copy the disk to an ISO.
I'm not sure yet if genisoimage can create a pure UDF.iso like for UHD, but it can create hybrids and of course 9660 (I still use it for CD+ audio discs). In addition to -udf it also supports -hfs images.
genisoimage -J -joliet-long -R -l -A "Authoring text; 128 max characters" -ldots -allow-multidot -V "volume name; 32 max characters" -o ./data.iso ./image_dirYou could also boot "KUbuntu" from USB and use K3b. It supports DVD-5/DVD-9 and bluray (mostly)... https://github.com/KDE/k3b
