I’m trying. Starting to think my hk file isn't getting updated. I get the same info if internet access is on or off. What/where is that file on Mac if I want to try and brute force this thing?MSCloude115 wrote: ↑Sat Jun 17, 2023 5:57 pmMike stated that while the site and forum are up and running the keys are not and I’m positive he will update when it is. The rest of us are waiting as well so we are gonna have to have patience.ionblue wrote: ↑Sat Jun 17, 2023 5:36 pmNow I'm just starting to lose my patience. It's been a full week since I sent the first dump and 4 days later sent it again.
MakeMKV v1.17.4 darwin(arm64-release) started
Optical drive "BD-RE ASUS BW-16D1HT 3.10 KLUJ5MD3517d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Saved AACS dump file as ***/Library/MakeMKV/MKB20_v77_John_Wick-_Chapter_4_51AE.tgz
John Wick 4
Re: John Wick 4
Re: John Wick 4
My 2 disk from amazon is working now. THANK YOU!
Re: John Wick 4
I removed the _private_data file and tried again. This time it downloaded the latest and I'm happily ripping away. Thanks Mike.
Re: John Wick 4
Ha ha ha.... I have to laugh cause after all that patience (or not) I have a bad disk. 2 drives, same failure pretty early on and the disc is clean as a whistle. Oh well. At least I'll be able to "try" to rip the next one when it arrives.
Re: John Wick 4
broken then it not... thank you for the update
Re: John Wick 4
2nd copy was good... even though it literally had a palm print on the backside. Definitely the worst disc I've bought over the years. And that's saying something! Good wiping did the trick. Just glad it actually ripped this round.
Re: John Wick 4
Wasn't able to rip the Aussie 4K release from StudioCanal, which is just a clone of the U.S disc with the Lionsgate logo on there and everything. Maybe different keys for the pressings they did for international distributors. Sent in my dump.
File name: MKB20_v77_John_Wick-_Chapter_4_D002.tgz
Re: John Wick 4
Also failing to rip the Aussie 4k steelbook, I've submitted my dump file too: MKB20_v77_John_Wick-_Chapter_4_D002.tgz. hopefully turn around on this is quick. looking forward to adding this to my collection
Re: John Wick 4
I've just been able to open my Aussie 4K disc! Same D002 dump file as you. Try it again and make sure your MakeMKV downloads the new HK file
Re: John Wick 4
Yep, I just picked up the Aussie Steel book from JB Hi-fi and is currently ripping!
Re: John Wick 4
So I was able to rip the movie. I got it from Amazon, watched it last night. Noticed this morning when I woke up to go back and check out a couple of scenes there were only two chapters. I happened to have just ripped the entire disc so I replaced it with the other of the same size into the folder and same deal. Only two chapters.
I am such a n00b at all of this I don't even know how to articulate what I am seeing and I don't know where to start looking. Can I get a little (big) nudge in the right direction?
Thank you!
-matt.
Thank you!
-matt.
Re: John Wick 4
Hello Mine also will not rip
MKB20_v77_John_Wick-_Chapter_4_0426.tgz
Re: John Wick 4
Matt, in MakeMKV you should see that 00800.mpls (FPL_MainFeature) is the playlist you want and it contains 16 chapters.matttowns509 wrote: ↑Sun Jul 09, 2023 7:05 pmSo I was able to rip the movie. I got it from Amazon, watched it last night. Noticed this morning when I woke up to go back and check out a couple of scenes there were only two chapters. I happened to have just ripped the entire disc so I replaced it with the other of the same size into the folder and same deal. Only two chapters.
Thank you!
-matt.
Re: John Wick 4
Hi Marty, thank you, I'll go look!
Re: John Wick 4
Thanks McNuts, I'm good!MartyMcNuts wrote: ↑Sun Jul 16, 2023 11:13 pmMatt, in MakeMKV you should see that 00800.mpls (FPL_MainFeature) is the playlist you want and it contains 16 chapters.matttowns509 wrote: ↑Sun Jul 09, 2023 7:05 pmSo I was able to rip the movie. I got it from Amazon, watched it last night. Noticed this morning when I woke up to go back and check out a couple of scenes there were only two chapters. I happened to have just ripped the entire disc so I replaced it with the other of the same size into the folder and same deal. Only two chapters.
Thank you!
-matt.
