Failure - 'The Hunt for Red October'
Yokozuna
Post by Yokozuna » Thu Jun 09, 2011 11:24 am
Movie would not rip.
Comes back with 3 titles. Second is unchecked. Size 5.2 GB
Press Go and pop-up displays "MakeMKV console application has stopped working" produces crash report and "Fatal error occurred, program will now exit".
Problem signature:
Problem Event Name: APPCRASH
Application Name: makemkvcon.exe
Application Version: 1.6.10.0
Application Timestamp: 4de285c5
Fault Module Name: makemkvcon.exe
Fault Module Version: 1.6.10.0
Fault Module Timestamp: 4de285c5
Exception Code: c0000005
Exception Offset: 0011f8a6
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 3081
Additional Information 1: 0a9e
Additional Information 2: 0a9e372d3b4ad19135b953a78882e789
Additional Information 3: 0a9e
Additional Information 4: 0a9e372d3b4ad19135b953a78882e789
Re: The Hunt for Red October
Post by mike admin » Fri Jun 10, 2011 2:00 pm
Yokozuna
Post by Yokozuna » Mon Jul 18, 2011 10:40 am
DVD rip fails soon after hitting go...
Debug log started at Mon Jul 18 10:35:42 2011 , written by MakeMKV v1.6.12 win(x86-release)
001005:0000 MakeMKV v1.6.12 win(x86-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\xxx/MakeMKV_log.txt
003025:0000 Title #0 has length of 1 seconds which
is less than minimum title length of 120 seconds and was therefore skipped
003025:0000 Title #1 has length of 92 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003024:1000 Complex multiplex encountered - 1 cells and 134 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #2 was added (16 cell(s), 2:09:29)
003024:1000 Complex multiplex encountered - 1 cells and 133 VOBUs have to be scanned. This may take some time, please be
003040:0000 Angle #2 was added for title #2
003028:0000 Title #3 was added (1 cell(s), 0:28:59)
005014:0000
Saving 2 titles into directory C:/Users/xxx/Downloads
Yokozuna
Post by Yokozuna » Tue Aug 09, 2011 8:55 am
Fatal Crash. Current build still does not work.
Post by mike admin » Sat Aug 13, 2011 3:02 pm
Yokozuna wrote:Fatal Crash. Current build still does not work.
Please, do submit a debug dump per instructions at http://www.makemkv.com/onlinehelp/dump.html as requested earlier. It's impossible to fix this error unless you submit the dump file. Thank you.
Yokozuna
Re: Failure - 'The Hunt for Red October'
Post by Yokozuna » Fri Sep 02, 2011 1:17 pm
Hi Mike,
DVD rip still fails. Crashes the program.
Log file attached.
MakeMKV_log.zip
(848 Bytes) Downloaded 737 times
setarip_old
Post by setarip_old » Fri Sep 02, 2011 7:08 pm
@Yokozuna
Hi!
Is your source material an original, commercial DVD?
Yokozuna
Post by Yokozuna » Thu Aug 02, 2012 2:27 pm
Mike,
When are you planning to address this? I have taken the effort to produce the dump files for you however there appears to be no action by your part to resolve?
setarip_old
Post by setarip_old » Thu Aug 02, 2012 4:45 pm
Since you are continuing to pursue this a year after your initial post, I'd again ask you:
geogan
Post by geogan » Sun Sep 16, 2012 5:48 pm
FYI: I'm getting the same program crash using latest makemkv v1.7.7 for winx64 when trying to do "Hunt for Red October - special collectors edition UK" (GB109961SV) Barcode:5014437835536. What do you want me to send? Would an ISO help?
Have done hundreds of DVD/Bluray - first time I saw an outright Windows program crash with makemkv...
p.s. Is your source material an original, commercial DVD? YES
Post by mike admin » Wed Sep 19, 2012 6:52 am
Please collect and send the debug dump per instructions at http://www.makemkv.com/onlinehelp/dump.html . Thanks in advance!
