Trying to rip Yellowstone Season 4.  Disk 3 contains episodes 7 - 9.  I was able to rip 8 & 9, but consistently getting errors on Ep7.
Basic troubleshooting tells me if I can get 2 of the episodes of the disk, there shouldn't be anything wrong with the Disk or the Reader, correct?
I have repeatedly cleaned the disk, restarted the computer, connected - disconnected - reconnected the drive, etc.
This is the summary of the error.  Attached the full log.
005003:0000 Failed to save title 0 to file E:/Shows/Yellowstone/Season 04/Yellowstone - s04e07.mkv
002023:0000 Encountered 17 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
error=0x06031105 count=17 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
002023:0000 Encountered 7 errors of type 'HashCheck Error' - see http://www.makemkv.com/errors/hashcheck/
error=0x070B0D08 count=7 name=Internal error - M2TS hash check failed (3336)
Encountered 18 unclassified errors
error=0x06020401 count=6 name=Scsi error - NOT READY:LOGICAL UNIT IS IN PROCESS OF BECOMING READY
error=0x80000016 count=1 name=OS error - {Verifying Disk} The media has changed and a verify operation is in progress so no reads or writes may be performed to the device, except those used in the verify operation
error=0xC000009C count=11 name=OS error - STATUS_DEVICE_DATA_ERROR
Any thoughts?
						Bluray RIP Failure on a Single Episode
Re: Bluray RIP Failure on a Single Episode
Yes, grab a new disc. It's most likely a defective disc/master. This happens a fair amount if you buy/rip a lot of TV shows.
Sent from my SM-G998U using Tapatalk
