Sisu
Bagdad48
Re: Sisu
#16 Post by Bagdad48 » Fri Jul 14, 2023 1:16 am
SamuriHL wrote: Fri Jul 14, 2023 12:31 am I already decrypted it and created the MKV. I will continue to check my protected ISO until MakeMKV supports it. But yes, it can take anywhere from a couple hours sometimes to multiple weeks others. It all depends on how busy Mike is. Patience is definitely required if you don't have multiple means of decrypting discs.
Awesome. Hopefully they key flows through soon. Still not able to get it to decrypt right now. Glad to see someone was able to make it work which means it should be coming soon.
Re: Sisu
#17 Post by SamuriHL » Fri Jul 14, 2023 3:35 am
The key is around but I don't think makemkv supports keydb anymore. At least I couldn't get it to work. So we have to wait for Mike to add it.
Re: Sisu
#18 Post by SamuriHL » Fri Jul 14, 2023 3:36 am
secrets secrets are no fun unless you share with everyone :)
How'd ya do it?
Still erroring out
I own multiple decryption products. But as I just mentioned the key is out in the keydb that's easily found.
jhayden2000
Re: Sisu
#19 Post by jhayden2000 » Fri Jul 14, 2023 1:48 pm
what do you do once you have the key?
Re: Sisu
#20 Post by SamuriHL » Fri Jul 14, 2023 2:27 pm
Well, if you have a program that has the key, use that program to make a decrypted folder and use MakeMKV to create the MKV from that. Otherwise if you have something that uses keydb.cfg format, you can create an entry in the keydb.cfg file and point that program to that file and it'll decrypt it. (VLC, as an example can be configured to use that format so you can at least play your title from a protected ISO while you wait for MakeMKV support).
tresnugget
Re: Sisu
#21 Post by tresnugget » Fri Jul 14, 2023 3:57 pm
SamuriHL wrote: Fri Jul 14, 2023 2:27 pm Well, if you have a program that has the key, use that program to make a decrypted folder and use MakeMKV to create the MKV from that. Otherwise if you have something that uses keydb.cfg format, you can create an entry in the keydb.cfg file and point that program to that file and it'll decrypt it. (VLC, as an example can be configured to use that format so you can at least play your title from a protected ISO while you wait for MakeMKV support).
That's what I just did.
I used Makemkv to backup the disc,
Downloaded explorefab to make a mini ISO out of the backup and mount it to a virtual drive
Used dvdfab passkey to make an unencrypted backup out of the original backup mounted in the virtual drive
Then finally used makemkv to make an mkv out of the unencrypted backup
I'm sure there's a more elegant solution but this way I didn't have to monkey with changing my drive firmware
Re: Sisu
#22 Post by SamuriHL » Fri Jul 14, 2023 8:16 pm
Key has been added to the hashed keys. Decrypting now.
rkhollister
Re: Sisu
#23 Post by rkhollister » Sun Jul 16, 2023 1:37 pm
Yup - worked fine for me in MakeMKV yesterday
