"After Hours" (1985) failing AACS 🥭
captain
#1 Post by captain » Thu Jul 13, 2023 2:35 pm
I emailed the dumpfile to svq@makemkv.com midday yesterday.
MKB20_v77_AFTER_HOURS_9F14.tgz
This disc has been out for THREE DAYS! Others have already ripped their copies. What's going on with MakeMKV... AND HOW are these other people ripping them already, when I cannot? :?: :|
jayper
Re: After Hours failing AACS 🥭
#2 Post by jayper » Thu Jul 13, 2023 2:57 pm
They're using a different tool to circumvent the disc's encryption. This is common, each tool has their own methods of decryption and receive support at different rates.
There's almost certainly nothing going on with MakeMKV or the development team. Sometimes discs get support on release day, sometimes it takes a little while. Just be patient.
captain
#3 Post by captain » Thu Jul 13, 2023 3:35 pm
That's what I figured. I did read that "after sending dumpfile it may take 12-48 hours...or longer"; I just wanted to be sure I'd sent it to the right place, in the right way, and wasn't supposed to find a thread here somewhere. :wink:
Yep. Patience grasshopper. Image Image
edit: heh. ok. enshrinkened emojis a bit
captain
#4 Post by captain » Thu Jul 13, 2023 3:36 pm
Is it just me, or are emojis showing up as ENORMOUS for everyone?! :-o
#5 Post by Woodstock » Thu Jul 13, 2023 3:49 pm
Emojis are that big, unless shrunken. The forum software doesn't include the code to shrink them, so they're shone at the full size they get downloaded as. It's irritating, but fixing it takes modifications to the forum software to recognize the image links and fix them up.
captain
Re: "After Hours" (1985) failing AACS 🥭
#6 Post by captain » Thu Jul 13, 2023 6:39 pm
FAIL! I didn't get a "this disc cannot be read" but the resultant files are unreadable. FML :-(
lidocaineus
#7 Post by lidocaineus » Thu Jul 13, 2023 7:02 pm
WOOT! It looks like the crew made the Key! Thanks y'all! :-D <3
I'll have to keep trying – mine downloads the latest key file, but still is unable to locate the specific key.
ChromePlanet
#8 Post by ChromePlanet » Fri Jul 14, 2023 3:06 pm
I also am having this issue with the UHD version from Criterion.
curiousMonkey
#9 Post by curiousMonkey » Fri Jul 14, 2023 11:11 pm
I think it will work now.
rkhollister
#10 Post by rkhollister » Sun Jul 16, 2023 1:36 pm
Working - ripped disc on July 15.
