Does the directoy "ANY!" make makemkvcon buggy?
flojo
Post by flojo »
Is the presence of the "ANY!" directory in the root of the FS the sole detection of AnyDVD? Makemkvcon won't be buggy solely because of that, correct?
I bought a supposed retail copy of "Race for Your Life Charlie Brown" from Amazon and it has the "ANY!" directory on the disc. Apparently it's a bootleg but as long as it rips O.K., I'm fine with that. This message is printed at the start of the rip: "It appears that you have AnyDVD enabled. ..." ... but I don't have AnyDVD.
MSG:1005,0,1,"MakeMKV v1.17.4 linux(x64-release) started","%1 started","MakeMKV v1.17.4 linux(x64-release)"
MSG:1009,0,1,"Profile parsing error: default profile missing, using builtin default","Profile parsing error: %1","default profile missing, using builtin default"
PRGT:5018,0,"Scanning CD-ROM devices"
PRGC:5018,0,"Scanning CD-ROM devices"
PRGV:0,0,65536
PRGV:0,0,65536
PRGV:65536,0,65536
PRGV:65536,65536,65536
DRV:0,0,999,0,"BD-RE ASUS BW-16D1HT 3.10 KL5L92D1732","","/dev/sr0"
DRV:1,256,999,0,"","",""
DRV:2,256,999,0,"","",""
DRV:3,256,999,0,"","",""
DRV:4,256,999,0,"","",""
DRV:5,256,999,0,"","",""
DRV:6,256,999,0,"","",""
DRV:7,256,999,0,"","",""
DRV:8,256,999,0,"","",""
DRV:9,256,999,0,"","",""
DRV:10,256,999,0,"","",""
DRV:11,256,999,0,"","",""
DRV:12,256,999,0,"","",""
DRV:13,256,999,0,"","",""
DRV:14,256,999,0,"","",""
DRV:15,256,999,0,"","",""
PRGV:0,65536,65536
PRGV:0,0,65536
MSG:1011,0,1,"Using LibreDrive mode (v06.3 id=0FA242DD4D0B)","%1","Using LibreDrive mode (v06.3 id=0FA242DD4D0B)"
MSG:5072,131072,1,"Backing up disc into folder \"file://.//temp__RACEFORYOURLIFECHARLIEBROWN\"","Backing up disc into folder \"%1\"","file://.//temp__RACEFORYOURLIFECHARLIEBROWN"
Disc opening found
PRGT:3404,0,"Opening Blu-ray disc"
PRGC:3400,0,"Processing AV clips"
PRGV:0,0,65536
PRGV:0,0,65536
PRGC:3401,0,"Processing movie playlists"
PRGV:4547,0,65536
PRGV:65001,0,65536
PRGC:3402,0,"Decrypting"
PRGV:0,0,65536
MSG:3335,1288,0,"It appears that you have AnyDVD enabled. MakeMKV should process discs with most sophisticated protections without help of any 3rd party decryption software. In addition MakeMKV works faster and more reliably when it decrypts data by itself. It is highly recommended to disable AnyDVD and restart the application.
Ezatoka
Re: Does the directoy "ANY!" make makemkvcon buggy?
Post by Ezatoka »
I would only be okay with that, as long as the disc still has full quality.
Can't say for sure, but I think, MakeMKV is looking in any directory on the disc for the MKB_RO.inf, MKV_RW.inf or Unit_Key_RO.inf and when it finds them in any directory but the AACS directory, it'll print out this warning.
I decrypted ISOs with BluRayTestAndDecrypt, which leaves a BTD! directory on the disc with the files and MakeMKV says, that it seems, I have on the fly decryption software active.
As long as there is no error on ripping, I would ignore this message.
