Sisu
jhayden2000
Re: Sisu
Thanks. I was coming here to do the exact same thing.
Re: Sisu
Me as well. Sisu cannot be decrypted even with VPN on
MakeMKV v1.17.4 win(x64-release) started
Using LibreDrive mode (v06.3 id=62194E19F4EC)
Saved AACS dump file as C:\Users\XXXX/.MakeMKV/MKB20_v77_Sisu_493E.tgz
Re: Sisu
So, I don't do this often enough to have a good feel for what a normal turnaround time on generating a key is. The FAQ says "a few days", which is fine but kinda vague. I don't mean to sound impatient, but I'm curious to see if anyone has a rough general feel for when a key for Sisu might drop.
Re: Sisu
1 day to 2 weeks it's just how it istcoble33 wrote: Thu Jul 13, 2023 1:52 pm So, I don't do this often enough to have a good feel for what a normal turnaround time on generating a key is. The FAQ says "a few days", which is fine but kinda vague. I don't mean to sound impatient, but I'm curious to see if anyone has a rough general feel for when a key for Sisu might drop.
Re: Sisu
Yeah, I figured it would be a pretty wide range. I don't know why I'm obsessing on this - it's not like I don't have the disc sitting right here if I really want to watch this movie...Billycar11 wrote: Thu Jul 13, 2023 1:55 pm1 day to 2 weeks it's just how it istcoble33 wrote: Thu Jul 13, 2023 1:52 pm So, I don't do this often enough to have a good feel for what a normal turnaround time on generating a key is. The FAQ says "a few days", which is fine but kinda vague. I don't mean to sound impatient, but I'm curious to see if anyone has a rough general feel for when a key for Sisu might drop.
Re: Sisu
I already decrypted it and created the MKV. I will continue to check my protected ISO until MakeMKV supports it. But yes, it can take anywhere from a couple hours sometimes to multiple weeks others. It all depends on how busy Mike is. Patience is definitely required if you don't have multiple means of decrypting discs.
Re: Sisu
secrets secrets are no fun unless you share with everyoneSamuriHL wrote: Fri Jul 14, 2023 12:31 am I already decrypted it and created the MKV. I will continue to check my protected ISO until MakeMKV supports it. But yes, it can take anywhere from a couple hours sometimes to multiple weeks others. It all depends on how busy Mike is. Patience is definitely required if you don't have multiple means of decrypting discs.
How'd ya do it?
Still erroring out
