#8521
Post
by RESET_9999 » Sat Jul 08, 2023 9:47 pm
speeddemon wrote: Sat Jul 08, 2023 2:52 pm
Which of these typically look most accurate to the original Profile 7?
depends on how the original p7 is I guess? (cmv2.9 or cmv4.0 / trims or not)
the best you can hope as I said, is cmv4.0 without trims and no point using anything else
#8522
Post
by RESET_9999 » Sat Jul 08, 2023 9:48 pm
valington wrote: Sat Jul 08, 2023 4:45 pm
Reset may be you could do one of your scripts without DRAG AND DROP where we could just put file into the folder and choose programm we need
this won't happen.
Drag and drop is a much better approach because your input can be anywhere in your PC (different drives)
dapope
#8523
Post
by dapope » Sun Jul 09, 2023 10:42 am
@RESET_9999
Salut, sorry for the maybe silly question but how do I get a DV P8 when baking in FEL using your 6-9 workflow? In changelog you say you added in option to export in DV but I still only get option for HDR or SDR.
#8524
Post
by RESET_9999 » Sun Jul 09, 2023 11:29 am
dapope wrote: Sun Jul 09, 2023 10:42 am
@RESET_9999
P7 rpu will be converted to P8 automatically so once the encoding is completed, just remux the hevc with mkvtoolnix or tsmuxer and DV P8 will be present.
dapope
#8525
Post
by dapope » Sun Jul 09, 2023 11:56 am
RESET_9999 wrote: Sun Jul 09, 2023 11:29 am
@RESET_9999
Ok, thanks very much! Is there an easy way to tell for myself what FEL titles have this issue?
dapope
#8527
Post
by dapope » Sun Jul 09, 2023 12:09 pm
Thanks but I meant to check myself in case there was a title you hadn't looked at. I guess you are pretty thorough, though.
#8528
Post
by RESET_9999 » Sun Jul 09, 2023 12:16 pm
dapope wrote: Sun Jul 09, 2023 12:09 pm
You plot L1 DV(6-2-3) and HDR10 (6-2-2) or you export screenshots with (6-8-1).
then compare the brightness.
#8529
Post
by RESET_9999 » Sun Jul 09, 2023 12:21 pm
you can also create some cool heatmap with 6-2-7
example:
https://slow.pics/c/2uVZCIH8
stehohrhase
#8530
Post
by stehohrhase » Tue Jul 11, 2023 4:39 am
Hi, in the sheet/comparson of DV-Stuff there are also itunes movies listed. I can not work with my files, bevause there are encrypted. Is there a database with the keys for the movies available ? Or somebody share Info, how to get the keys ? Generally i know, how provsioning works, but i have no Info, to get the needed keys from a device, with is not dongraded to L3. Or ist there other option ? Gladyl PM, when this is OT.
Lapihin_A
#8531
Post
by Lapihin_A » Tue Jul 11, 2023 7:57 pm
Please advise, I have two videos completely synchronized and with the same number of frames. The task is to add HDR10+ metadata from one video to the other. The two videos differ in frame size but with the same aspect ratio, the donor video with HDR10+ 1600p and the patient video 2160p. Question - is it possible to add HDR10+ metadata from one video to the other and vice versa if both videos differ in frame size? Is there any parameter similar to Level 5 in HDR10+ metadata as in Dolby Vision?
fransalas
#8532
Post
by fransalas » Thu Jul 13, 2023 8:35 pm
Hello I'm hallucinating with your tool, I have a question .. I have several series in SDR and I have seen that your tool with the command 6-9 converts to HDR10 but the CPU shoots up to 100% and as your tool says -- Encode FEL P7 or HLG or P5 to HDR10 or SDR with ffmpeg/libx265/libx26/ibplacebo/dovi_baker
-- Require an Nvidia gpu that supports Vulkan.
-- Input must be P7 Single-Track for FEL to P8 encoding and require Avisynthplus and dovi.dll.
refers to having an NVIDIA Vilkan GPU and I have a 4090 that I have observed does not work when I run the tool... It could be some configuration failure?.. thanks I am waiting in case anyone knows the answer or can guide me
#8533
Post
by RESET_9999 » Thu Jul 13, 2023 11:49 pm
fransalas wrote: Thu Jul 13, 2023 8:35 pm
The script cannot convert SDR to HDR.
You need software like Davinci Resolve if you want to do that.
#8534
Post
by RESET_9999 » Thu Jul 13, 2023 11:51 pm
Lapihin_A wrote: Tue Jul 11, 2023 7:57 pm
https://github.com/quietvoid/hdr10plus_tool
fransalas
#8535
Post
by fransalas » Fri Jul 14, 2023 8:24 am
Some explanatory manual of how to perform the process with DaVinci
