#8521 Post by RESET_9999 » Fri Jul 07, 2023 10:37 pm
IMO, It's better to generate a new RPU in resolve because:
1- if you use hdr10plus, your min_pq will always be 0
2- HDR10plus avg_pq is VERY different than what Dolby Vision produces. DV has some specific calculations for the avg_pq.
3- with Resolve, you can make true CMV4.0 metadata (with L3) which improves tone mapping.
speeddemon
#8522 Post by speeddemon » Fri Jul 07, 2023 11:02 pm
Thanks! Understood.
Another question... have you done much research yet comparing Resolve Analyzed output with typical metadata that includes L2/L8 trims?
#8523 Post by RESET_9999 » Fri Jul 07, 2023 11:22 pm
Yes
For some reason, resolve does not export the L8 trims similar to when you set your project to cmv2.9 which does not export L2.
So for the resolve cmv4.0 output, a cmv4.0 device won't have any trims effect: only L1 + L3 but for a cmv2.9 device, automatic L2 trims will brighten everything below the tv capabilities and darken every thing above.
BTW, I think only one time I've seen an actual CMV4.0 rpu with active L8... strangely, everything else doesn't have any L8 trim or it's set to 2048 no effect.
There's a bunch of test files in my GD in which you can test pretty much everything DV related.
https://drive.google.com/drive/u/1/fold ... V0E3VVkhiC
speeddemon
#8524 Post by speeddemon » Sat Jul 08, 2023 12:24 am
Is the L2 part actually true for both CMv2.9 and CMv4 analysis when outputting both when outputting CMv2.9 or CMv4? Or, do you just strip the L2 trims when processing with your script anyways?
#8525 Post by RESET_9999 » Sat Jul 08, 2023 1:03 am
trims are reset to 0 or removed depending on your script configuration. You can set the script to keep the trims but by default, they are overwritten as explained a couple of days ago in this thread
speeddemon
#8526 Post by speeddemon » Sat Jul 08, 2023 1:09 am
And you recommend the trims being overwritten for the reasons you stated earlier, correct?
But, just to make sure I understand correctly, can you confirm the following with regards to Resolve?
  1. CMv2.9 Analysis & CMv2.9 output = L1
  2. CMv4 Analysis & CMv2.9 output = L1+L2
  3. CMv4 Analysis & CMv4 output = L1+L3 in CMv4 or L1+L2 in CMv2.9 Fallback
#8527 Post by RESET_9999 » Sat Jul 08, 2023 1:12 am
That's correct.
Actually, the L8 100nits trim is exported but it's set to 0 and obviously not useful to DV playback.
speeddemon
#8528 Post by speeddemon » Sat Jul 08, 2023 2:52 pm
That's correct.
Which of these typically look most accurate to the original Profile 7?
valington
#8529 Post by valington » Sat Jul 08, 2023 4:45 pm
That's correct.
Reset may be you could do one of your scripts without DRAG AND DROP where we could just put file into the folder and choose programm we need
#8530 Post by RESET_9999 » Sat Jul 08, 2023 9:47 pm
depends on how the original p7 is I guess? (cmv2.9 or cmv4.0 / trims or not)
the best you can hope as I said, is cmv4.0 without trims and no point using anything else
#8531 Post by RESET_9999 » Sat Jul 08, 2023 9:48 pm
this won't happen.
Drag and drop is a much better approach because your input can be anywhere in your PC (different drives)
dapope
#8532 Post by dapope » Sun Jul 09, 2023 10:42 am
@RESET_9999
Salut, sorry for the maybe silly question but how do I get a DV P8 when baking in FEL using your 6-9 workflow? In changelog you say you added in option to export in DV but I still only get option for HDR or SDR.
#8533 Post by RESET_9999 » Sun Jul 09, 2023 11:29 am
@RESET_9999
P7 rpu will be converted to P8 automatically so once the encoding is completed, just remux the hevc with mkvtoolnix or tsmuxer and DV P8 will be present.
dapope
#8534 Post by dapope » Sun Jul 09, 2023 11:56 am
@RESET_9999
Ok, thanks very much! Is there an easy way to tell for myself what FEL titles have this issue?
#8535 Post by RESET_9999 » Sun Jul 09, 2023 12:00 pm
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
