Dragon Tattoo Trilogy (Extended Edition)
noobster27
Post by noobster27 » Sun Jul 09, 2023 6:01 am
So i ripped Dragon Tattoo Trilogy (Extended Edition) which includes "The girl with the dragon tattoo/The girl that played with fire/The girl that kicked the hornets nest" All part of the millennium trilogy. Been that they are extended editions every movie is split into two. Which leads to the tricky part of the titling to see how plex grabs them. Anyone have a solution or suggestion?
Re: Dragon Tattoo Trilogy (Extended Edition)
Post by d00zah » Sun Jul 09, 2023 5:55 pm
Movies Split Across Multiple Files
/Movies
/The Dark Knight (2008)
The Dark Knight (2008) - pt1.mkv
The Dark Knight (2008) - pt2.mkv
Notes:
  • Not all Plex apps support playback of stacked media
  • All parts must be of the same file format (e.g. all MP4 or all MKV)
  • All parts should have identical audio and subtitle streams in the same order
  • Only stacks up to 8 parts are supported
  • “Other Videos” libraries or those using the “Plex Video Files Scanner” do not support stacked content.
However, to get a better overall experience, we encourage you to instead use a tool to join/merge the individual files into a single video. There are multiple ways you can do this and a quick search in your favorite search engine should give you some options on how to “join” files. An unofficial guide with one free tool has even been posted in our forums.
Like MKVToolNix.
Joining Videos without Conversion using MKVToolNix
