Hi folks,
Trying to extract episodes from my backup of the Battlestar Galactica Season 4.5 Disk 3, I got for the first time an apparent assertion failure from MakeMKV 1.4.6. The first and third real titles on the disk extract fine; the second doesn't and always fails at the same place about a third of the way in.
Running in W7 7100 32 bit, 4 GB RAM on a dual core AMD X2 Kuma. No problems with other discs; this is my first recent failure. Extraction is from an Iso I made of my disk; running Anydvdhd 6.5.7.4 with Elby Virtual Clone Drive hosting the image.
Complete log follows:
Debug log started at Sun Aug 09 19:57:55 2009 , written by MakeMKV v1.4.6 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.6 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\Users\HomeTheater/MakeMKV_log.txt
001012:000000:0020 FAILURE: Code 3221225488 at Ee'sS]F'4oT]Sm:213130927
001012:000000:0020 FAILURE: Code 3221225488 at o9KTzxA0Z`r$,p]y:121263061
001012:000000:0020 FAILURE: Code 0 at o9KTzxA0Z`r$,p]y:121262762
001012:000000:0020 FAILURE: Code 0 at *FzC!K#7-J)0{4T/peb5JkZH;O:29393516
005042:000000:0000 The program can't find any usable optical drives. The BETA version requires administrative privileges for drive access.
005041:000000:0404 The folder "L:" appeares to be a root folder on optical drive, however drive can't be accessed by the program. The operation will most likely fail.
003006:000000:0000 Opening files on harddrive at L:/
003310:000000:0000 AACS directory not present, assuming unencrypted disc
003020:000000:0000 Title #00099.mpls has length of 118 seconds which is less than minimum title length of 120 seconds and was therefore skipped
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00004
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00005
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00006
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00046
003313:000000:0000 File 00010.mpls was added as title #0
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00106.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00010.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00107.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00095.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00108.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00098.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00109.m2ts
003313:000000:0000 File 00030.mpls was added as title #1
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00040
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00060
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00061
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00062
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00063
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00064
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00065
001011:000000:0020 LIBMKV_TRACE: No CC5 in 00066
003313:000000:0000 File 00020.mpls was added as title #2
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00103.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00104.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00099.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00105.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00100.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00163.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00101.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00114.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00110.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00115.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00111.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00116.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00112.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00117.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00113.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00118.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00097.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00119.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00096.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00120.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00102.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00137.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00138.m2ts
003313:000000:0000 File 00031.mpls was added as title #3
003313:000000:0000 File 00021.mpls was added as title #4
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00122.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00123.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00124.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00125.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00126.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00127.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00128.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00129.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00130.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00131.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00132.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00133.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00134.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00135.m2ts
003316:000000:0000 Only extracting DTS core audio from stream #1 of type 'DTS-HD Master audio' in file 00136.m2ts
003313:000000:0000 File 00022.mpls was added as title #5
003314:000000:0000 Title 00032.mpls is equal to title 00022.mpls and was skipped
003020:000000:0000 Title #00000.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00001.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00002.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00011.m2ts was added as title #6
003020:000000:0000 Title #00050.m2ts has length of 61 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00061.m2ts has length of 54 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00078.m2ts was added as title #7
003313:000000:0000 File 00080.m2ts was added as title #8
003313:000000:0000 File 00081.m2ts was added as title #9
003313:000000:0000 File 00082.m2ts was added as title #10
003313:000000:0000 File 00083.m2ts was added as title #11
003313:000000:0000 File 00084.m2ts was added as title #12
003313:000000:0000 File 00085.m2ts was added as title #13
003020:000000:0000 Title #00086.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00087.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00088.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00089.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00090.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00091.m2ts has length of 9 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00092.m2ts has length of 14 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00093.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00094.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00139.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00140.m2ts has length of 91 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00141.m2ts has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00142.m2ts has length of 68 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00143.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00144.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00145.m2ts has length of 80 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00146.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00147.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00148.m2ts has length of 96 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00149.m2ts has length of 110 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00150.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00151.m2ts has length of 79 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00152.m2ts has length of 101 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00153.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00154.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00155.m2ts has length of 104 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00156.m2ts has length of 90 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00157.m2ts has length of 89 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00158.m2ts has length of 69 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00159.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00160.m2ts has length of 74 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00161.m2ts has length of 83 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003020:000000:0000 Title #00162.m2ts has length of 93 seconds which is less than minimum title length of 120 seconds and was therefore skipped
003313:000000:0000 File 00164.m2ts was added as title #14
003314:000000:0000 Title 00030.mpls is equal to title 00020.mpls and was skipped
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory F:/Video/Battlestar_Galactica_Season_4_5_(Disc_3)
001012:000000:0020 FAILURE: Code 4 at *"MQ'hY%B{%6F^dgmsO:29396644
001012:000000:0020 FAILURE: Code 3 at *"MQ'hY%B{%6F^dgmsO:29396644
001011:000000:0020 LIBMKV_TRACE: Exception: MKV_ASSERT: frame->timecode>=cluster_timecode
005003:000000:0000 Failed to save title 3 to file F:/Video/Battlestar_Galactica_Season_4_5_(Disc_3)/title03.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
I posted a synopsis to the failure sticky; if I can try anything to help debug let me know. Thanks.
Marc
Assertion failure: Battlestar Galactica S4.5 D3
Marc_G
Re: Assertion failure: Battlestar Galactica S4.5 D3
Thanks for reporting. The log file shows nothing of interest unfortunately, is it a main episode failing or some additional feature?
On a side note, you'll get beteer performance by opening iso image directly (from File-Open) rather than mounting it in VCD.
Marc_G
Mike,
Thanks for the reply. Here is some further information.
This disk wouldn't open in makemkv as an iso; it failed before getting to the track listings screen.
The episode I had trouble extracting is one of three on the disk. The other two extract fine.
The one that fails seems to be listed twice, once with size and chapters, once just size, same size for both.
Anything else I should try? Other logs I can give?
Marc
Marc
Marc_G
Is there any file I can supply that would enable you to dig into this?
Marc
Marc
Marc_G
For what it's worth, I was finally able to rip this episode using RibBot264. But it took about 10 hours!
The next version will have this problem corrected. Thanks for sending logs - it helped.Marc_G wrote:Is there any file I can supply that would enable you to dig into this?
Marc
Marc_G
Excellent! Thanks for your attention. Glad the logs helped. Looked like gobbledygook to me but I figured you might be able to do something with it.
Great work on this software.
One question: do you have any recommendation what I should do with some 1080i VC1 content I ripped out of Torchwood season 3? Apparently the common decoders don't like interlaced VC1 content. I'm looking for an easy solution to play them, short of using PowerDVD to play the .iso. Any decent codec I can simply register and enable with FilterTweaker without disabling the WMF or anything intense like that? I just use DD/DTS audio via SPDIF. Nothing fancy on that score.
Marc
Marc
