LibreDrive for Pioneer drives
Post by Billycar11 » Fri Jul 07, 2023 12:38 am
i3lue wrote: Fri Jul 07, 2023 12:33 am looks like this drive is currently a no go but I would like confirmation.
Manufacturer: PIONEER
Product: BD-RW BDR-XS07U
Revision: 1.03
Serial number: CEDL011829UC
Firmware date: 2023-01-06
Bus encryption flags: 13
Highest AACS version: 76
Firmware version: ID05
see post above
i3lue
Post by i3lue » Fri Jul 07, 2023 12:45 am
Billycar11 wrote: Fri Jul 07, 2023 12:38 am
see post above
thanks
i3lue
Post by i3lue » Fri Jul 07, 2023 3:20 am
I just found a very old drive collecting dust on my shelf.
it is an internal drive and none of my systems have a slot for internal right now so have it dangling outside of my open case.
it is a Pioneer BDR-208DBK with a MFD of Feb 2013.
maybe it can't do UHD but it should do my regular Blurays.
anyone know if it can be made to do UHD?
it is a bit of a speed demon on this regular rip hitting ~7-8x speed right now.
Product: BD-RW BDR-208D
Revision: 1.10
Serial number: MBDL049731WL
Firmware date: 2012-08-22
Drive platform: RS8301
Firmware name: PIONEER BDR-208
Firmware version: 1.10/ID61
Post by MartyMcNuts » Fri Jul 07, 2023 4:08 am
i3lue wrote: Fri Jul 07, 2023 3:20 am I just found a very old drive collecting dust on my shelf.
Revision: 1.10
Nope. It is too old. UHD wasn't around back in 2012/13.
Post by Billycar11 » Fri Jul 07, 2023 5:39 am
Revision: 1.10
email me about this drive i have a $25 flasher for it to make it do UHD
i3lue
Post by i3lue » Sat Jul 08, 2023 5:47 am
Billycar11 wrote: Fri Jul 07, 2023 5:39 am
Thanks that worked.
RollingZ
Post by RollingZ » Sat Jul 08, 2023 10:38 pm
From what I can gather in this thread, my new Pioneer drive with info
OS device name: /dev/sr0
Product: BD-RW BDR-L08SHB
Revision: 1.15
Serial number: MLDL390651WL
Firmware date: 2018-01-24
Highest AACS version: 72
Drive platform: Pioneer RS8301
Firmware version: ID92
Disc Information
Label: THE_PRINCESS_BRIDE
Timestamp: 2012-07-13 10:35:31
Protection: AACS v28, BD+ v2012.7
Data capacity: 42.3 Gb
Disc type: BD-ROM
Number of layers: 2
Won't be able to get past this
MakeMKV v1.17.4 linux(x64-release) started
Evaluation version, 9 day(s) out of 30 remaining
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..03F to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..03F to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..07F to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..07F to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0BF to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0BF to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A30..0020..0FF to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..0020..0FF to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command A40..002000800 to device 'SG:dev_21:1'
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while issuing SCSI command AD010..080002400 to device 'SG:dev_21:1'
Downloading latest HK to /home/dan/.MakeMKV ...
Saved AACS dump file as /home/dan/.MakeMKV/MKB_v28_The_Princess_Bride_CC5A.tgz
Until maybe sometime in the future when its too-new firmware can be made to allow LibreDrive? Just confirming before I give up for the time being.
Thanks. I emailed the dump_FW file a few days ago.
Post by Billycar11 » Sun Jul 09, 2023 2:41 am
RollingZ wrote: Sat Jul 08, 2023 10:38 pm From what I can gather in this thread, my new Pioneer drive with info
Revision: 1.15
Disc Information
Disc type: BD-ROM
Number of layers: 2
disc issue not drive
RollingZ
Post by RollingZ » Sun Jul 09, 2023 3:18 am
really? The same basic error happens with every disc I try. Only the very first was ever readable.
But if it's only the disc, I can enable LibreDrive?
Post by Billycar11 » Sun Jul 09, 2023 8:09 am
RollingZ wrote: Sun Jul 09, 2023 3:18 am really? The same basic error happens with every disc I try. Only the very first was ever readable.
all libredrive does for is is to be able to rip UHD and get around aacs new version locks.
you issue here is read errors it looks like to me or a passthrough issue with your linux container
RollingZ
Post by RollingZ » Mon Jul 10, 2023 4:30 am
Turns out same disc plays on VLC, except for the menus. Just rolls right through the main video.
Yes, linux is wonky with this. Won't play without telling it where java is. Then it plays even though the menus fail.
So the drive is fine, maybe some similar compatibility issue with makemkv as with vlc. This is on ubuntu 22.04, I'll see if windows works.
$ JAVA_HOME=/usr/lib/jvm/default-java/bin/java vlc
VLC media player 3.0.16 Vetinari (revision 3.0.13-8-g41878ff4f2)
[000055f687665580] main libvlc: Running vlc with the default interface. Use 'cvlc' to use vlc without interface.
[000055f6877054a0] main playlist: playlist is empty
bdplus.c:372: [bdplus] mmap: PSR register file at 0x7f07fc003980
bdplus_config.c:346: [bdplus] mmap: register file 2 not mapped in config
bdplus.c:377: [bdplus] mmap: GPR register file at 0x7f07fc003b80
bdplus_config.c:346: [bdplus] mmap: register file 4 not mapped in config
loader.c:81: [bdplus] WARNING: BD+ generation 13 not tested / supported
bdj.c:781: BD-J check: Failed to load JVM library
[00007f07fc001130] libbluray demux: First play: 0, Top menu: 0
HDMV Titles: 0, BD-J Titles: 81, Other: 81
[00007f07fc001130] libbluray demux error: BD-J menus not supported. Playing without menus. BD-J support: 1, JVM found: 0, JVM usable: 0
trap.c:188: [TRAP] TRAP_Aes(AES_ECB_DECRYPT_MEDIA_KEY) not implemented
internal.c:84: [bdplus] Scanning /home/dan/.config/bdplus for cached conversion table...
internal.c:158: [bdplus] Found cached conversion table at /home/dan/.config/bdplus/convtab/17660864673BCC31C68C04F35EEE9DC1_THE_PRINCESS_BRIDE.bin
bdplus.c:253: [bdplus] loading cached conversion table /home/dan/.config/bdplus/convtab/17660864673BCC31C68C04F35EEE9DC1_THE_PRINCESS_BRIDE.bin ...
segment.c:987: [segment] loading cached convTable file
segment.c:759: [segment] activating conv_tab.bin
bdplus.c:332: [bdplus] using cached conversion table for 00057.m2ts
bdplus.c:353: BD+ active for clip 00057.m2ts
[00007f07fc001130] libbluray demux: Adding ES 4113 select 1
[00007f07fc001130] libbluray demux: Adding ES 4352 select 1
[000055f687736070] main audio output error: too low audio sample frequency (0)
[00007f08080c6630] main decoder error: failed to create audio output
[00007f07fc001130] libbluray demux: Adding ES 4353 select 0
[00007f07fc001130] libbluray demux: Adding ES 4354 select 0
[00007f07fc001130] libbluray demux: Adding ES 4355 select 0
[00007f07fc001130] libbluray demux: Adding ES 4356 select 0
[00007f07fc001130] libbluray demux: Adding ES 4608 select 0
[00007f07fc001130] libbluray demux: Adding ES 4609 select 0
[000055f687736070] vlcpulse audio output error: digital pass-through stream connection failure: Not supported
[000055f687736070] main audio output error: module not functional
[00007f07ec004910] gl gl: Initialized libplacebo v4.192.1 (API v192)
libva info: VA-API version 1.14.0
libva info: Trying to open /usr/lib/x86_64-linux-gnu/dri/radeonsi_drv_video.so
libva info: Found init function __vaDriverInit_1_14
libva info: va_openDriver() returns 0
[00007f07ec1a2870] gl gl: Initialized libplacebo v4.192.1 (API v192)
[00007f07ec9efc20] gl gl: Initialized libplacebo v4.192.1 (API v192)
[00007f0808005770] main decoder error: buffer deadlock prevented
[00007f0808000ec0] ts demux error: libdvbpsi error (misc PSI): Bad CRC_32 table 0x2 !!!
[00007f07fc001130] libbluray demux: Closing overlays.
QObject::~QObject: Timers cannot be stopped from another thread
bultom
Post by bultom » Sun Jul 23, 2023 4:26 pm
Hey :)
Saw new firmware update for my Drive ... did it ... shouldn't done that :lol:
Informations lecteur
Nom du lecteur SE : \Device\CdRom1
Profil actuel : BD-ROM
Fabricant : PIONEER
Produit : BD-RW BDR-S12U
Révision : 1.04
Numéro de série : ***************
Date micrologiciel : 2022-12-20
Marqueurs d'encryptage bus : 1B
Version AACS la plus haute : 76
Status: Possible, not yet enabled <== was possible before update (on 1.02 or 1.03 don't remember)
Drive platform: Pioneer RS8F01
Firmware version: ID43
Information du disque
Titre: John Wick
Horodatage: 2019-09-30 13:43:36
Protection: AACS2.0/C v70
Capacité de données : 93.21 Gb
Type de disque : BD-ROM UHD
Nombre de couches : 3
Marqueurs d'encryptage bus : 80
back to waiting state :mrgreen:
ama0riko
Post by ama0riko » Wed Jul 26, 2023 7:04 am
Hi, this is my first time here so there are probably going to be some spots in my knowledge.
I'm looking to get a Pioneer drive that I can just purchase and will work with ripping pretty much any content.
- I live in Japan and so getting my hands on second-hand Pioneer drives with older firmware is not a problem.
- I use macOS
I'm looking to get a BDR-XD07J-UHD (should just be the Japanese version of the BDR-XD07UHD) with a manufacturing date on the back of the drive that reads March 2018.
Would this be a good choice? I would really appreciate if I can get opinions on this.
Post by Billycar11 » Wed Jul 26, 2023 8:34 am
ama0riko wrote: Wed Jul 26, 2023 7:04 am Hi, this is my first time here so there are probably going to be some spots in my knowledge.
- I use macOS
that would work long as someone didn't update it for you
vila818
Post by vila818 » Thu Jul 27, 2023 12:38 am
Seems to be working.
