NO ERROR: Way of Water won't RIP (Not a key issue)
noworries1968
Post by noworries1968 » Tue Jul 04, 2023 3:29 am
Avatar 1 RIP'd fine.... no problems.
Way of Water stops at a file size of ~7.5GB.
MakeMKV continues to run, but the conversion essentially stops.
There is no error, no key issue, nothing.
Drive is a Pioneer and is compatible, has RIP'd 100's of discs thus far.
Any help appreciated.
Re: NO ERROR: Way of Water won't RIP (Not a key issue)
Post by MartyMcNuts » Tue Jul 04, 2023 4:33 am
Try giving the disc a good clean.
noworries1968
Post by noworries1968 » Tue Jul 04, 2023 5:46 pm
Will give that a try...
But now I'm getting an error:
Input/Output error
Posix error
No log generated that I can see...
noworries1968
Post by noworries1968 » Tue Jul 04, 2023 6:04 pm
Good cleaning..done.
No change.
I'm exchanging the disc for another, as it's brand new.
Just unsure if that will correct the problem.
noworries1968
Post by noworries1968 » Tue Jul 04, 2023 6:05 pm
Hardware Error 441E
noworries1968
Post by noworries1968 » Tue Jul 04, 2023 6:17 pm
Drive is a Pioneer BDRXS07U 1.01
