Avatar 1 RIP'd fine.... no problems.
Way of Water stops at a file size of ~7.5GB.
MakeMKV continues to run, but the conversion essentially stops.
There is no error, no key issue, nothing.
Drive is a Pioneer and is compatible, has RIP'd 100's of discs thus far.
Any help appreciated.
NO ERROR: Way of Water won't RIP (Not a key issue)
noworries1968
Re: NO ERROR: Way of Water won't RIP (Not a key issue)
Try giving the disc a good clean.noworries1968 wrote: ↑Tue Jul 04, 2023 3:29 amAvatar 1 RIP'd fine.... no problems.
noworries1968
Will give that a try...
But now I'm getting an error:
Input/Output error
Posix error
No log generated that I can see...
Input/Output error
Posix error
noworries1968
Good cleaning..done.
No change.
I'm exchanging the disc for another, as it's brand new.
Just unsure if that will correct the problem.
No change.
noworries1968
Hardware Error 441E
noworries1968
Drive is a Pioneer BDRXS07U 1.01
