angel has Fallen uhd
Blubbs73
Post by Blubbs73 » Tue Jul 04, 2023 4:58 am
sorry im new to this and i cant get angel has fallen uhd to rip got bluray to rip any help appricated paul
Re: angel has Fallen uhd
Post by Woodstock » Tue Jul 04, 2023 5:39 pm
Information on what happened would make it easier than just posting "it didn't work". Things like what kind of drive you're using would be especially helpful, along with specific errors your received.
Blubbs73
Post by Blubbs73 » Wed Jul 05, 2023 10:00 pm
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIK03N3IA5647
Firmware date: 2120-05-07 09:35
Highest AACS version: 76
Firmware version: 1.02
Disc Information
Disc is being loaded
just wont load not sure what else u need sometimes it doies get past fist screen after 10 mins but not always
Post by Billycar11 » Thu Jul 06, 2023 1:41 am
Revision: 1.02
Disc Information
Usual thing to try are
Let windows see the disc first then open makemkv after that.
Clean the disc
Replace the disc
Clean the drive
Get high powered USB hub or use 2 back USB ports on desktop pc
Replace the drive.
Blubbs73
Post by Blubbs73 » Fri Jul 07, 2023 3:54 am
turns out to be faulty disc but thanks for help
