angel has Fallen uhd
Blubbs73
sorry im new to this and i cant get angel has fallen uhd to rip got bluray to rip any help appricated paul
Re: angel has Fallen uhd
Information on what happened would make it easier than just posting "it didn't work". Things like what kind of drive you're using would be especially helpful, along with specific errors your received.
Blubbs73
Product: BD-RE BP60NB10
Revision: 1.02
Serial number: SIK03N3IA5647
Firmware date: 2120-05-07 09:35
Highest AACS version: 76
Firmware version: 1.02
Disc Information
Disc is being loaded
just wont load not sure what else u need sometimes it doies get past fist screen after 10 mins but not always
Revision: 1.02
Disc Information
Usual thing to try areBlubbs73 wrote: Wed Jul 05, 2023 10:00 pm Drive Information
Revision: 1.02
Disc Information
Let windows see the disc first then open makemkv after that.
Clean the disc
Replace the disc
Clean the drive
Get high powered USB hub or use 2 back USB ports on desktop pc
Replace the drive.
Blubbs73
turns out to be faulty disc but thanks for help
