Error messages not readable
tedster41
Post by tedster41 »
I've been having an issue where whenever I get an error or popup, the text is covered entirely by a black box. I'm using v1.16.7 on an XP machine, and I've been having this problem since I installed it. It's not usually a problem because I can just assume what it's asking and move on, but recently I've been trying to export a DVD and it just isn't working. The file is 6.2GB, in case it's something to do with it's size, but a pop-up will appear with a yes or no input when I press the button to convert it. If I select yes, it skips the entire DVD and stops. If I select no, it says '0 titles saved, 1 failed' with no other explanation. I'm saving it directly to a USB drive with more than enough storage to hold it, and that has saved many files onto it directly like this before. If someone has a fix for either of these problems, please let me know.
Re: Error messages not readable
What format is your USB drive? I think the file size limit for FAT 32 formatted file systems is 4GB.
tedster41
Post by tedster41 »
It is FAT 32, yes, so that might be the issue. I'll try saving it on an NTFS drive instead when I get the chance.
tedster41
Post by tedster41 »
Just tried it with an NTFS drive, and it worked perfectly. Still not sure about the text bug, but the software is working fine nonetheless. Thanks!
