makemkvcon on fedora FC10 SIGSEGV
vartista
#1 Post by vartista » Sun Aug 09, 2009 6:09 pm
Hi There,
I've tried previously with 1.4.4 and now with 1.4.6 but I'm unable to run makemkvcon on Fedora 10:
$ sudo  /usr/bin/makemkvcon info
001014:000000:0000 MakeMKV v1.4.6 beta linux(x86-release) started
Current action: Scanning CD-ROM devices
Segmentation fault
or sometimes with a different output:
Current progress - 0%  , Total progress - 0%
Segmentation fault
One suspicious thing is that I have to add an exception to SELinux after compiling and installing the makemkv libs:
message from SELinux: "The makemkvcon application attempted to load /usr/lib/libmakemkv.so.1 which requires text relocation."
$sudo chcon -t textrel_shlib_t '/usr/lib/libmakemkv.so.1'
Running an strace did not help:
mmap2(NULL, 10489856, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_PRIVATE|MAP_ANONYMOUS|MAP_STACK, -1, 0) = 0x2da9000
mprotect(0x2da9000, 4096, PROT_NONE)    = 0
clone(child_stack=0x37a94a4, flags=CLONE_VM|CLONE_FS|CLONE_FILES|CLONE_SIGHAND|CLONE_THREAD|CLONE_SYSVSEM|CLONE_SETTLS|CLONE_PARENT_SETTID|CLONE_CHILD_CLEARTID, parent_tidptr=0x37a9bd8, {entry_number:6, base_addr:0x37a9b90, limit:1048575, seg_32bit:1, contents:0, read_exec_only:0, limit_in_pages:1, seg_not_present:0, useable:1}, child_tidptr=0x37a9bd8) = 29200
futex(0x83c956c, FUTEX_WAKE_OP_PRIVATE, 1, 1, 0x83c9568, {FUTEX_OP_SET, 0, FUTEX_OP_CMP_GT, 1}) = 1
nanosleep({0, 100000000},  <unfinished ...>
+++ killed by SIGSEGV +++
gdb did not help either:
Starting program: /usr/bin/makemkvcon info
[Thread debugging using libthread_db enabled]
[New Thread 0xb7fe26d0 (LWP 29252)]
[New Thread 0x177fb90 (LWP 29253)]
[New Thread 0x795eb90 (LWP 29254)]
Program received signal SIGSEGV, Segmentation fault.
[Switching to Thread 0x795eb90 (LWP 29254)]
0x082192e4 in strcpy () at strcpy.c:39
39	      c = *s++;
(gdb) where
#0  0x082192e4 in strcpy () at strcpy.c:39
#1  0x0795e0d8 in ?? ()
#2  0x082197b8 in strcpy () at strcpy.c:39
#3  0x00000001 in ?? ()
#4  0x00844d7c in ?? ()
#5  0x0a1c0aeb in ?? ()
#6  0x41b3ad52 in ?? ()
#7  0x0000000a in ?? ()
#8  0xe54e175c in ?? ()
#9  0x00000001 in ?? ()
#10 0x0116e3fd in ?? ()
#11 0xe4762da6 in ?? ()
#12 0x23a8cfdf in ?? ()
#13 0x00000000 in ?? ()
(gdb)
any ideas?
Thanks a lot
Re: makemkvcon on fedora FC10 SIGSEGV
#2 Post by mike admin » Tue Aug 11, 2009 8:40 am
We can try to debug. We would need core dump and makemkv libs compiled on your system (I assume that you're getting the core dump when app crashes).
vartista
#3 Post by vartista » Tue Aug 11, 2009 5:41 pm
The core dump is too big to post here -> http://rapidshare.de/files/48091242/mak ... ar.gz.html
I can also confirm that I get the same exact behaviour on my other machine running FC9.
Would it help with a debug enabled version of makemkvcon executable? even without the source code one could see the stack.
Is it possible that I'm the only one with this problem on FC9, 10?
Thanks again,
vartista
#4 Post by vartista » Tue Aug 11, 2009 5:59 pm
Here's the entry I get in /var/log/messages:
makemkvcon[11132]: segfault at af1d7f ip 082192e4 sp 03b7e018 error 4 in makemkvcon[8048000+380000]
CybrFyre
#5 Post by CybrFyre » Fri Aug 21, 2009 10:16 pm
Hi. I am having pretty much the same experience on Fedora 11 64-bit
I do have a core I can upload if you have a ftp someplace.
Thanks.
ps Fedora 11's stock openssl also is lacking the elliptical curve crypto. So, I ended up just compiling the latest snapshot of openssl 1.0 from source and pointing makemkv at that.
#6 Post by mike admin » Mon Sep 28, 2009 10:38 am
MakeMKV 1.4.7 should compile and run fine. Please confirm.
vartista
#7 Post by vartista » Fri Oct 09, 2009 9:04 pm
I can confirm that v1.4.8 works on FC10.
Thanks and you can close this thread.
btw great work with makemkv !
