Convert m2ts Files
nkhan
Convert m2ts Files
Post by nkhan » Wed Jun 08, 2011 9:32 pm
I have been using a MKV for a while now, i have some of my backups in m2ts files and would like to put these in MKV format.
Basically i used makeMKV to back up disk to hard drive originally, can i still use these to convert to MKV or do i need to start from scratch with the disc.
Thank you
Romansh
Re: Convert m2ts Files
Post by Romansh » Wed Jun 08, 2011 11:22 pm
Just open the backup with MakeMKV using the "Open files" button found in the toolbar.
setarip_old
Post by setarip_old » Thu Jun 09, 2011 1:29 am
and select either "index.bdmv" or "MovieObject.bdmv" from the "BDMV" folder/directory...
nkhan
Post by nkhan » Thu Jun 09, 2011 10:48 am
Ok, thank you.
I was trying to do it with the Streams folder and was blank.
