cant get avatar 2 full movie to be first on plex
mattiswise
Post by mattiswise »
no matter what i try, a special feature will be the main title folder, though i see the movie listed at the top, player just skips right to bonus
Sunoo
Re: cant get avatar 2 full movie to be first on plex
Post by Sunoo »
Sounds like you have your files named wrong.
Post by d00zah »
mattiswise wrote:
Tue Jun 27, 2023 7:08 pm
Maybe the Organized in Subdirectories section?
https://support.plex.tv/articles/local- ... nd-extras/
I always put 'extras' in a subfolder, usually 'Other' just to simplify things.
Fix Match might also be helpful.
Radiocomms237
Post by Radiocomms237 »
Yes, extras must be placed in sub-folders or they will be recognized as movie files.
As an example, this is the contents of my folder called "Blade Runner (1982)" within my Plex movie library:
All the extras are categorized (although, as @dcoke22 said, they don't necessarily need to be) in separate sub-folders, and different editions of the same movie are located in the main folder with each edition labelled as shown.
Note that the description, which is everything after {edition- can be whatever you want it to be.
Plex's multiple edition support is only available to Plex Pass subscribers. Probably worth mentioning just in case someone who isn't a subscriber starts to lose their mind trying to make it work. :)
