Copy complete. 0 titles saved, 1 failed
Timmay
Post by Timmay » Wed Aug 05, 2009 1:56 pm
I was looking for a tool that can convert AVCHD to mkv and found out about MakeMKV.
It looks like the perfect tool for me, but I can't get it working...
I have an ISO file, and when I add it, everything seems ok
But when I press om the Make MKV button, I get this error:
I tried it with different ISO's, saving the file in different locations, but that also didn't work.
I use Windows 7 64bit.
Can anybody tell me what i'm doing wrong?
Re: Copy complete. 0 titles saved, 1 failed
Post by mike admin » Thu Aug 06, 2009 8:17 am
Please enable "show debug log" in preferences, restart app and share the produced log file. Be shure to attach the actual .txt file and feel free to edit out any personal information.
troppo
Post by troppo » Sun Aug 09, 2009 7:08 am
I also have this problem but it has only started happening today. I downloaded the beta and successfully installed and used the program converting VOB files...no problems for the first 20 or so dvd then all of a sudden the program has stopped converting anything and everything.
I have restarted my PC, uninstalled and re-installed Makemkv and even re-downloaded the Makemkv installer again..all to no avail.
The debug log is;
Debug log started at Sun Aug 09 06:48:54 2009 , written by MakeMKV v1.4.6 beta win(x86-release)
001014:000000:0000 MakeMKV v1.4.6 beta win(x86-release) started
001013:000000:0000 Debug logging enabled, log will be saved as C:\xxxxx\xxxxx/MakeMKV_log.txt
003006:000000:0000 Opening files on harddrive at C:/xxxxx/xxxxx/xxxxx/xxxxx/xxxxx/xxxxx/VIDEO_TS/
003036:000000:0000 Title #0 was added (35 cell(s), 1:51:28)
001012:000000:0020 FAILURE: Code 2028 at {V4?4/#]=H'+-a_T6kW:121262785
001012:000000:0020 FAILURE: Code 0 at QW.:v(HC[49&%g[k~]\a:121262164
001012:000000:0020 FAILURE: Code 7 at QW.:v(HC[49&%g[k~]\a:213129639
001012:000000:0020 FAILURE: Code 1 at %7>'H}OW#;u6c|):29403314
005011:000000:0000 Operation sucessfully completed
005014:000000:0000 Saving 1 titles into directory D:/xxxxx/xxxxx
001012:000000:0020 FAILURE: Code 0 at J>waNuq@Ex?2uBWD9wRp$:121264211
001012:000000:0020 FAILURE: Code 0 at [Ph>Xo\vo{y421s!9m,:121263268
001012:000000:0020 FAILURE: Code 0 at [Ph>Xo\vo{y421s!9m,:121261888
FS ID=V_MPEG2 C=1
C_00000=ZeNp1yMsNgkAURmFmhreK8lRE8AE9ubQBi3BFQkH2YE8sxkkQc1z4Jyf57tX6d9afKZM0BSaB/+t7CEte9fiY/Oxv4/CxCO+2U02WsIJt2IFd2IN9OIBDeAEv4RUcwWt4A8dwAqdwBudwAW/hHVzCe7iCD3ANN/ARPsFn+AK3cDf7DRMDL6I=
001012:000000:0020 FAILURE: Code 0 at [Ph>Xo\vo{y421s!9m,:29393838
001012:000000:0020 FAILURE: Code 0 at J>waNuq@Ex?2uBWD9wRp$:121264326
001012:000000:0020 FAILURE: Code 0 at *"MQ'hY%B{%6F^dgmsO:121261980
001012:000000:0020 FAILURE: Code 0 at *"MQ'hY%B{%6F^dgmsO:213131502
001011:000000:0020 LIBMKV_TRACE: Exception: Error while reading input
005003:000000:0000 Failed to save title 0 to file D:/xxxxx/xxxxx/title00.mkv
005004:000000:0000 0 titles saved, 1 failed
005037:000000:0204 Copy complete. 0 titles saved, 1 failed.
Application exited at Sun Aug 09 06:49:52 2009
I hope you can help
JSmith19
Post by JSmith19 » Wed Sep 09, 2009 12:45 pm
Same issue here I tried it over and over someone a solution?
Debug logging enabled, log will be saved as C:\Users\xxxx/MakeMKV_log.txt
FAILURE: Code 3221225488 at Ee'sS]F'4oT]Sm:213130927
FAILURE: Code 3221225488 at o9KTzxA0Z`r$,p]y:121263061
FAILURE: Code 0 at o9KTzxA0Z`r$,p]y:121262762
FAILURE: Code 0 at *FzC!K#7-J)0{4T/peb5JkZH;O:29393516
The program can't find any usable optical drives. The BETA version requires administrative privileges for drive access.
Opening files on harddrive at //xxxxxx/xxxxxx/downloads/complete/Serie DVD/smallville_seizoen_1/smallville seizoen 1 DVD 4/SMALLVILLE_S1_D4/VIDEO_TS/
Calculated BUP offset does not match one in IFO header.
Cells 7-6 were skipped due to cell commands (structure protection?)
Cells 13-12 were skipped due to cell commands (structure protection?)
Cells 19-18 were skipped due to cell commands (structure protection?)
Title #0 was added (24 cell(s), 2:46:21)
Title #1 was added (24 cell(s), 2:46:21)
Cell 7 was discarded (structure protection?)
Cells 8-end were skipped due to cell commands (structure protection?)
Title #2 was added (6 cell(s), 0:41:54)
Title #3 was added (6 cell(s), 0:39:42)
Title #4 was added (6 cell(s), 0:42:24)
Title #5 was added (6 cell(s), 0:42:21)
Title 6 in VTS 1 is equal to title 1 and was skipped
Saving 1 titles into directory C:/Users/xxxxxx/Downloads/xxxxxx/Serie DVD/smallville_seizoen_1/smallville seizoen 1 DVD 4
FAILURE: Code 49 at [Ph>Xo\vo{y421s!9m,:213133365
Failed to save title 3 to file C:/Users/xxxxxx/Downloads/xxxxxx/Serie DVD/smallville_seizoen_1/smallville seizoen 1 DVD 4/title03.mkv
