Hey, sorry if it's redundant but I'm not able to find that issue in the forum.
MAKEMKV 1.17.4
Macos 10.14.6
I've been using makemkv for years without an issue.
Now, I have those files from a bluray, wich I can't open in makemkv :
I noticed index.bdmv is located under BACKUP directory, not under BDMV directory as usual.
When i open the index.bdmv files, I got nothing but the message : failed to open disc.
Any idea ? Thx a lot for your help.
Open index.bdmv produce nothing
Re: Open index.bdmv produce nothing
Your rip is missing a ton of things, especially the video files. Yes, in the backup directory, there is a copy of index.bdmv as well:
(https://i.imgur.com/DHeBg37.png if picture isn't loading)
but the original should be within BDMV:
(https://i.imgur.com/cSer7LM.png if picture isn't loading)
And without the stream directory, there are no video files on your "BuRay":
(https://i.imgur.com/Q5b6HXD.png if picture isn't loading)
Oh you're right, I feel so stupid...
Thanks anyway.
Thanks anyway.
