One Episode of House MD not ripping
2wicky
Post by 2wicky » Fri Jun 23, 2023 2:22 pm
I get this error when trying to rip House MD Season 3 Episode 15. I've ripped the rest without issue. Any ideas what it could be?
Saving 1 titles into directory //library/tv/House MD/House MD Season 3
Error 'OS error - STATUS_DEVICE_NOT_CONNECTED' occurred while reading '/BDMV/STREAM/00280.m2ts' at offset '2302015488'
Error 'OS error - The volume for a file has been externally altered such that the opened file is no longer valid' occurred while reading '\Device\CdRom1' at offset '2302015488'
Error 'OS error - This device does not exist' occurred while reading '/BDMV/STREAM/00280.m2ts' at offset '2302015488'
Failed to save title 3 to file //library/tv/House MD/House MD Season 3/House - Season 3 Disc 3_t03.mkv
Re: One Episode of House MD not ripping
Post by Woodstock » Fri Jun 23, 2023 4:27 pm
The drive apparently shut down during the rip. Is this a USB-powered device?
2wicky
Post by 2wicky » Sat Jun 24, 2023 4:16 am
Yes it is. It stops at the exact same point each time too. It cruises through the first bit then at 1790.4 it gets hung up and starts throwing the error.
Post by Woodstock » Sat Jun 24, 2023 11:47 pm
Exact same spot is unusual... same AREA isn't. The main thing to try is slowing the read down so that the drive does not exceed USB power limits, OR getting the drive sufficient power to not stop when it tries to go fast.
Did the drive come with a two-head cable? If so, how do you have it configured? Plugging both heads into the same hub only works if it's a powered hub.
2wicky
Post by 2wicky » Mon Jul 10, 2023 4:35 am
It is a 2 headed cable but I've only one plugged in to my cpu. This is the only file I've had this issue with oddly. Read speed is 18.9 M/s when it throws the error. When I'm ripping uhd discs, read speed tops out at 25 without issue
