valington wrote:
Tue Jun 20, 2023 6:04 pm
DUNE HD REAL VISION shows DT DL with full blu ray 4k dolby vision and ST DL with bdremux mkv 7 profile dolby vision is it true dolvy visiob or not ?
It's true DV but without FEL support meaning only the dynamic metadata in the RPU is used.
@RESET_9999,
I am having trouble with the script (using 1.8.3) 2-2 to extract the RPU. I've done this heaps of times over the past couple of weeks, mind you, this is the first attempt since a major Windows 11 update the other day. I haven't changed anything. Here is the log.
Input #0, mpegts, from 'F:\Movies\The_Transformers_The_Movie\BDMV\STREAM\00006.m2ts':
Duration: 01:25:00.83, start: 600.000000, bitrate: 97757 kb/s
Program 1
Stream #0:0[0x1011]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 3840x2160 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn
Stream #0:1[0x1100]: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000 Hz, stereo, s32p (24 bit)
Stream #0:2[0x1101]: Audio: dts (DTS-HD MA) ([134][0][0][0] / 0x0086), 48000 Hz, 5.1(side), s32p (24 bit)
Stream #0:3[0x1102]: Audio: ac3 (AC-3 / 0x332D4341), 48000 Hz, stereo, fltp, 192 kb/s
Stream #0:4[0x12a0]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:5[0x12a1]: Subtitle: hdmv_pgs_subtitle ([144][0][0][0] / 0x0090)
Stream #0:6[0x1015]: Video: hevc (Main 10) (HDMV / 0x564D4448), yuv420p10le(tv, bt2020nc/bt2020/smpte2084), 1920x1080 [SAR 1:1 DAR 16:9], 23.98 fps, 23.98 tbr, 90k tbn
Automatic encoder selection failed for output stream #0:0. Default encoder for format hevc (codec none) is probably disabled. Please choose an encoder manually.
Error selecting an encoder for stream 0:0
Error: No frames parsed!
Error: No NALU start codes found in the file. Maybe not a valid RPU?
FINDSTR: Cannot open H:\DoVi_Scripts_1.8.3_TOOLS\TEMP_folder7\test.xml
Parsing RPU file...
Parsing RPU file...
L5 Left offset: L5_is_missing_you_should_edit...
L5 Right offset: L5_is_missing_you_should_edit...
L5 Top offset: L5_is_missing_you_should_edit...
L5 Bottom offset: L5_is_missing_you_should_edit...
HDR10 BL MDL: min: 0.0001 cd/m2, max: 1000 cd/m2
HDR10 BL MDP: Display P3
Resolution: 3840 x 2160
FrameRate: 23.976fps
Duration: 5100.804seconds
the script has completed...
It looks like the DV layer stream ID is wrong (6 instead of 1). You'll have to demux that one manually.
powdeau
Post by powdeau »
@RESET_9999,
I've noticed that some of your RPU files don't have L2 trims for 600 and 1000 nits (e.g. Evil Dead Rise or Avatar). Wouldn't it cause a problem on x700 with C1, since x700 ignores L1 metadata and uses only L2?
powdeau wrote:
Thu Jun 22, 2023 6:27 pm
@RESET_9999,
IMO, the L2 trims can only be done/edited by the colorist/director so for our Resolve generated RPU, I recommend removing or overwriting the automatic trims otherwise they can make bright content very dark and dark content brighter which might not be the intended look.
see: https://www.youtube.com/watch?v=ZoseTlZ1JG4
Of all the movies I checked the metadata, only one time I noticed that the studios used the automatic trims but they forgot to do the blanking(black bar exclusion) which messed up everything.
see: https://slow.pics/c/tB3PBcPT
otherwise, the trims are almost always edited manually after the dv analysis.
see: https://slow.pics/c/Ozrwnmvr
The x700 does not ignore L1, at least not in TV-LED.
https://drive.google.com/file/d/1gctmX1 ... drive_link
First, grade the HDR image on your Dolby Vision Certified Mastering Monitor to look as
you want it to. Dolby recommends starting by setting the look of the HDR image, to set
the overall intention for the grade.
2 When using various grading controls in the Color page to grade HDR images, you may
find it useful to enable the HDR Mode of the node you’re working on by right-clicking
that node in the Node Editor and choosing HDR mode from the contextual menu. This
setting adapts that node’s controls to work within an expanded HDR range. Practically
speaking, this makes controls that operate by letting you make adjustments at different
tonal ranges, such as Custom Curves, Soft Clip, etcetera, work more easily with wide-
latitude signals.
3 When you’re happy with the HDR grade, click the Analysis button in the Dolby Vision
palette. This analyzes every pixel of every frame of the current shot, and performs and
stores a statistical analysis that is sent to the CMU to guide its automatic conversion of
the HDR signal to an SDR signal.
4 If you’re not happy with the automatic conversion, use the Lift/Gamma/Gain/Chroma
Weight/Chroma Gain controls in the Dolby Vision palette to manually “trim” the result to
the best possible Rec. 709 approximation of the HDR grade you created in step 1. This
stores what Dolby refers to as “artistic guidance” metadata.
5 If you obtain a good result, then move on to the next shot and continue work. If you
cannot obtain a good result, and worry that you may have gone too far with your HDR
grade to derive an acceptable SDR downconvert, you can always trim the HDR grade a
bit, and then re-trim the SDR grade to try and achieve a better downconversion. Dolby
recommends that if you make significant changes to the HDR master, particularly if you
modify the blacks or the peak highlights, you should re-analyze the scene. However, if
you only make small changes, then reanalyzing is not strictly required
As you can see, the general idea promoted by Dolby is that a colorist will focus on grading the
HDR picture relative to the 1000, 2000, 4000, or higher nit display that is being used, and will
then rely on the colorist to use the Dolby Vision controls to “trim” this into a 100 nit SDR
version with artistic guidance. This “artistic guidance” metadata is saved as part of the mastered
media, and it’s used to more intelligently scale the HDR highlights to fit within any given HDR
display’s peak highlights, to handle how to downconvert the image for SDR displays, and also
how to respond when a television’s ABL circuit kicks in. In all of these cases, the colorist’s
artistic intent is used to guide all dynamic adjustments to the content.
powdeau
Post by powdeau »
RESET_9999 wrote:
Thu Jun 22, 2023 7:19 pm
Thank you for the deep explanation. So in your script, I should change "Choose if you want to remove the 600 and 1000nits L2 trim pass" to "YES", right?
You’re right, I’ve mixed it up with "L1 low contrast and L2 offset 0.75" problem.
powdeau wrote:
Thu Jun 22, 2023 8:01 pm
If you have access to the Dolby Metafier, yes. If you don't, you can set the script to just overwrite all the trims. This is how the script is set by default.
::choose if you want to overwrite L2 trims to 2048(no effect) for the XML to RPU conversion (YES or NO default = YES).
set drop.L2=YES
::Choose if you want to remove the 600 and 1000nits L2 trim pass. in other words, do you want to keep the L2 100nits trim (only valid for 1-1 and xml input) (require the dolby metafier and this option override: ''set drop.L2=YES'') (default=NO)
set rem_600_1000=NO
The L1 problem with the x800m2/x700 seem to be with low nits contents (under 1000nits). It's almost like the player knows the content is within the TV capabilities and decides to ignore L1 while the other devices(shield c2 internal,firestick) just apply the L1 metadata regardless of the content brightness.
That is actually a much bigger problem. I did more tests about it and it turns out, any value over 2048 for trim offset has no effect in TV-LED mode on X700 x800m2 and Shield and most likely all the true TV-LED devices
If you force LLDV, then it's working properly.
This a bigger problem than the LLDV bug because Trim offset is used a lot more often in movies than Trim Chroma weight (lldv issue). By default the Dolby algo does not touch to Chroma Weight, it has to come from the colorist but Trim offset on the other hand, it's calculated automatically by the algo. FYI, values over 2048 make the image brighter. Trim offset test file: https://drive.google.com/file/d/1JrU6JX ... drive_link
difference with quietvoid L2 test file: https://www.avsforum.com/threads/pictur ... t-62609139
Example of movie with active trim offset with positive lift:
TheEqualizer
Post by TheEqualizer »
RESET_9999 wrote:
Sun Jul 25, 2021 9:48 pm
first, you have to find the frame difference between the two videos. Personally, I use MPC-BE and find the same frame for both videos, press ''control-g'' and calculate the frame number difference. You can navigate frame by frame with ''control left/right arrow'' when the video is paused.
then the framecount of both rpu and hdr10 video must match. so you calculate how many frames you have to remove or add at the end of the rpu. (include the frame you added or removed from the start of the rpu) ... just math at this point.
EDIT: it is no more needed to calculate the framecount since the latest update. You only need to calculate the frame difference so the rpu is in sync with the bluray remux.
Good afternoon, I want to clarify once and for all for myself, in cases where dv has fewer frames than hdr, for example
hdr=185248
dv=185200
.json will look like (please write here an example with numbers)
Conversely, when DV has more frames than HDR, for example
HDR=185200
DV=185248
.json will look like (please write an example with numbers here). Thank you in advance!
why do you want to manually create JSON for that when the dovi_tool will do it for you?
anyway, you have all the json examples on the dovi tool github
https://github.com/quietvoid/dovi_tool/ ... r_examples
TheEqualizer
RESET_9999 wrote:
Fri Jun 23, 2023 1:30 pm
I don't want to do everything by hand! I was in this github directory, but due to not knowing English and using a translator, maybe I misunderstood somewhere. How dovi_tools do everything for me? Clarify please! When introducing rpu into hdr at the final stage, I see a warning about a different number of frames, respectively, I understand that you need to manually align them, if you remove the extra ones it’s easier and clearer, then adding the missing ones is not very clear the whole process, that’s why I asked for an example json file code with specific figures for clarity. If I'm doing something wrong, explain again the procedure, maybe the script can do it all and there is no need for manual adjustment
If your sources are already in sync, you dont have to worry about the framecount mismatch at the end and the dovi_tool will duplicate or remove the right amount of frames automatically.
If your sources are not in sync, you have to find the frame difference and then input the difference in the script (1-1).
You cant calculate the frame difference just by looking at the frame count of both sources.
TheEqualizer
RESET_9999 wrote:
Fri Jun 23, 2023 4:26 pm
Thanks, it's much clearer now
hjkl1234
Post by hjkl1234 »
RESET_9999 wrote:
Thu Jun 08, 2023 11:07 am
it looks like your path to the tool ''jq.exe'' is not right or missing.
here's the folder for all the tools:
https://drive.google.com/file/d/1qavvq_ ... sp=sharing
Could you reupload the tools? I've been searching everywhere but I couldn't find the Tools and I tried to install all the necessary files from the tools_readme.txt but some of them were missing and I don't know how exactly some repos needed to be in the folder.
Would be great if you can send it to me.
speeddemon
Post by speeddemon »
quietvoid wrote:
Fri May 12, 2023 11:03 am
NiCE77 wrote:
Fri May 12, 2023 10:55 am
Thanks, but I found this comment: https://github.com/erazortt/DoViBaker/i ... 1259843741
So the result will not be good if we inject the RPU because double processing. But then I don't really understand what this tool is for?
Reinjecting the *original* RPU is wrong. When converted to profile 8.1 it is fine.
As long as you don't tonemap using the trims in DoViBaker.
DoViBaker uses the mapping metadata and NLQ metadata to reconstruct the FEL image.
All this metadata is removed by profile 8.1 conversion (for FEL).
Would it be possible to have a version of DoVi_Scripts someday that uses DoViBaker and dovi_tool to reconstruct the FEL image and output a correct P8.1 file?
@quietvoid & @RESET_9999 have either of you considered teaming up with erazortt to do this?
quietvoid
Post by quietvoid »
speeddemon wrote:
Sun Jun 25, 2023 3:42 am
The output wouldn't be easily playable if it sticks to lossless encoding, as the files would be huge.
And there are too many variables when reencoding lossy, so it's probably not worth it.
