Billycar11 is your auto flash kit a solution to this issue? Really hoping to get back to ripping 4K again as quickly as possible.Billycar11 wrote: Thu Jun 08, 2023 1:26 pmNo solution yetdomvar wrote: Thu Jun 08, 2023 1:24 pm I'm a bit lost in these replies is there a solution to the 1.04 firmware issue yet ether by flashing or other? No problem if not but the thread seems to have drifted away form that.
Re: Pioneer firmware update February 2023
no not yet for now it can only cross flash pioneers fron non UHD to UHD and also needs fw before dec 2022TiKiMaN1 wrote: Fri Jun 09, 2023 1:18 amBillycar11 is your auto flash kit a solution to this issue? Really hoping to get back to ripping 4K again as quickly as possible.Billycar11 wrote: Thu Jun 08, 2023 1:26 pmNo solution yetdomvar wrote: Thu Jun 08, 2023 1:24 pm I'm a bit lost in these replies is there a solution to the 1.04 firmware issue yet ether by flashing or other? No problem if not but the thread seems to have drifted away form that.
Does the hex editing firmware version not work?
Hi Billicar11,Billycar11 wrote: Fri Jun 09, 2023 1:54 amno not yet for now it can only cross flash pioneers fron non UHD to UHD and also needs fw before dec 2022TiKiMaN1 wrote: Fri Jun 09, 2023 1:18 amBillycar11 is your auto flash kit a solution to this issue? Really hoping to get back to ripping 4K again as quickly as possible.
I own a Pioneer BDR-S12XLT.
Drive information:
OS device name: Z:
Producer: PIONEER
Product: BD-RW BDR-S12
Revision: 1.01
Firmware date: 2020-07-21
Bus Encryption Marks: 1B
Highest AACS version: 72
LibreDrive information
State: Enabled
Drive platform: RS8F00
Firmware version: 1.01/ID45
I want to upgrade my drive from non-UHD to UHD
switch
Does this work with your program?
can you provide it to me
Greetings Yamikawa
Email me this I should be able to do ityamikawa wrote: Fri Jun 09, 2023 8:00 pmHi Billicar11,Billycar11 wrote: Fri Jun 09, 2023 1:54 amno not yet for now it can only cross flash pioneers fron non UHD to UHD and also needs fw before dec 2022TiKiMaN1 wrote: Fri Jun 09, 2023 1:18 am
Drive information:
OS device name: Z:
Producer: PIONEER
Revision: 1.01
State: Enabled
switch
Greetings Yamikawa
MKVtesterB
I am just receiveing following drive:
PIONEER BD-RW BDR-UD04 USB Device
Date du pilote 21/06/2006
Version du pilote 10.0.22621.1
Fournisseur du pilote Microsoft
Fichier INF cdrom.inf
INF Section cdrom_install
Identification du matériel USBSTOR\CdRomPIONEER_BD-RW___BDR-UD041.14
I want use is to make backup of my UHD BD disque and use it on my TV via PLEX
is it useful to install the latest Freedrive compatible firmware?
Test it for UHD first. If it works then do not change firmware.MKVtesterB wrote: Fri Jun 23, 2023 12:31 pm Hi,
Am I correct that the below drive (even though it has firmware 1.02) should be OK once the small firmware dump is uploaded and MakeMKV updated? I'm assuming that's the case based on LibreDrive "Possible, not yet enabled."
My return window is closing in a week or so, so if this drive is definitely NOT usable for UHD (in the long term), then I'll return it. If it IS indeed usable, even it might take a while for the MakeMKV update, then I'd just as well keep it.
OS device name: /dev/sr0
Manufacturer: PIONEER
Product: BD-RW BDR-XD08U
Revision: 1.02
Serial number: CCDL300593UC
Firmware date: 2022-12-27
Highest AACS version: 76
Drive platform: Pioneer RS9331
Firmware version: ID05-
Nope. The firmware is too new. It shows as 27 Dec 2022. Any firmware dated Dec 2022 or newer is no good. It could be months before we have a resolution.pitcher27 wrote: Fri Jun 23, 2023 11:51 pm Am I correct that the below drive (even though it has firmware 1.02) should be OK once the small firmware dump is uploaded and MakeMKV updated? I'm assuming that's the case based on LibreDrive "Possible, not yet enabled."
Drive Information OS device name: /dev/sr0 Manufacturer: PIONEER Product: BD-RW BDR-XD08U Revision: 1.02 Serial number: CCDL300593UC Firmware date: 2022-12-27 Bus encryption flags: 1B Highest AACS version: 76 LibreDrive Information Status: Possible, not yet enabled Drive platform: Pioneer RS9331 Firmware version: ID05
return it and get a pioneer from me asmcom or marty depending on location we have ones that are flashedpitcher27 wrote: Fri Jun 23, 2023 11:51 pm Am I correct that the below drive (even though it has firmware 1.02) should be OK once the small firmware dump is uploaded and MakeMKV updated? I'm assuming that's the case based on LibreDrive "Possible, not yet enabled."
MKVtesterB
i'ts working with UHD tooMartyMcNuts wrote: Fri Jun 23, 2023 9:49 pmTest it for UHD first. If it works then do not change firmware.MKVtesterB wrote: Fri Jun 23, 2023 12:31 pm Hi,
Recently bought a pioneer drive due to libredrive support (or so I thought), reliablility, and UHD. Sadly it came with 1.04 firmware which appears I'm in trouble as MakeMKV folks haven't figured out a solution yet. Should I return the drive or are we making headway to unlock the 1.04 firmware drives.
if you cant wait return it and buy one of my pioneers if your in the usa.jcfrosty wrote: Thu Jun 29, 2023 1:15 am Recently bought a pioneer drive due to libredrive support (or so I thought), reliablility, and UHD. Sadly it came with 1.04 firmware which appears I'm in trouble as MakeMKV folks haven't figured out a solution yet. Should I return the drive or are we making headway to unlock the 1.04 firmware drives.
but if you can wait i hear you may not even need to flash it with a future libredrive update
but i have mine here ready and waiting now ready to go out tomorrow
BigfootAUS
Bought a fresh Pioneer BDRS12UHT from Amazon Australia this week, the drive arrived with 1.04. Info tab:
At least it's still working with regular blurays; I had a Verbatim 43888 mechanically fail after ripping just one 4K disc and 2 DVDs, couldn't even detect regular blurays once it started breaking. This Pioneer drive seems much more reliable and has gone through more content without issue already, so I'm keen to see a fix to use this drive. Just seems better overall.
Is there anything we can do to help? Logs of anything?
OS device name: H:
Product: BD-RW BDR-S12U
Revision: 1.04
Serial number: [serial number was here]
Firmware date: 2022-12-20
Highest AACS version: 78
Drive platform: Pioneer RS8F01
Firmware version: ID43
I have no problem keeping it if we can get it working eventually. In the meantime, it benefits me to have 2 drives for separate machines. One stays connected to the server, so I just ordered a pioneer from you as well to keep me running since my LG desktop drive died after a year and 4 months.Billycar11 wrote: Thu Jun 29, 2023 7:05 amif you cant wait return it and buy one of my pioneers if your in the usa.jcfrosty wrote: Thu Jun 29, 2023 1:15 am Recently bought a pioneer drive due to libredrive support (or so I thought), reliablility, and UHD. Sadly it came with 1.04 firmware which appears I'm in trouble as MakeMKV folks haven't figured out a solution yet. Should I return the drive or are we making headway to unlock the 1.04 firmware drives.
Pioneer seems more reliable as my first pioneer BD (non UHD) drive lasted well over 5 years. Really dissatisfied with LG.
