Post by Billycar11 » Thu Jun 15, 2023 12:09 am
zaqqaz6917 wrote: Wed Jun 14, 2023 7:29 pm
Billycar11 wrote: Wed Jun 14, 2023 1:35 am
jpankonien wrote: Wed Jun 14, 2023 12:44 am Does the Pioneer BDR-S13UBK require flashing?
worse it cant be flashed currently by the public so if the fw is after 12/2022 you cant rip uhd with it.
for now pioneers you must buy from a flasher like me marty or asmcom we can flash pioneers.
@ Billy
Can you flash the S13UBK as well?
as cooper says i can only flash pioneers from before 12/22
zaqqaz6917
Post by zaqqaz6917 » Thu Jun 15, 2023 1:46 am
Thanks to both Cooper and Billy for the info.
Umino
Post by Umino » Thu Jun 15, 2023 3:20 pm
ASUS BW-16D1HT does not read the disk after brushing 3.10MK firmware.
Now I can't flash back the firmware I backed up, and I'm at a loss.
Do any good people know that I can still be saved?
When I opened the it to observe its working state, I found that it seems that only the tray is still working at present ...
oval5765
Post by oval5765 » Thu Jun 15, 2023 5:23 pm
Does anyone happen to have the sdf.bin handy? Downloading it from the website isn't working since certificate seems to have expired.
sclawrenc
Post by sclawrenc » Mon Jun 19, 2023 11:45 pm
I just registered just to say THANK YOU! I just flashed my LG BP60 drive using the SDF Flasher GUI and it seems to worked perfectly. Now to learn how to backup my UHD discs so that I can share them to my Apple TVs. Thanks again.
baneling
Post by baneling » Thu Jun 22, 2023 5:24 pm
hey all, I have the LG BP60NB10 and ripped several discs successfully. Last night I ripped a disc and a few times it was making a buzzing sound for a few seconds. it sounded like something was touching a spinning fan or something. has anyone experienced this before?
Post by MartyMcNuts » Fri Jun 23, 2023 3:03 am
baneling wrote: Thu Jun 22, 2023 5:24 pm hey all, I have the LG BP60NB10 and ripped several discs successfully. Last night I ripped a disc and a few times it was making a buzzing sound for a few seconds. it sounded like something was touching a spinning fan or something. has anyone experienced this before?
Perhaps your disc wasn't clicked in correctly or maybe the disc is slightly warped?
baneling
Post by baneling » Fri Jun 23, 2023 12:43 pm
MartyMcNuts wrote: Fri Jun 23, 2023 3:03 am
I took out the disc and put it back in and made sure it was in properly. Maybe it was warped. but if it was warped, wouldn't the noise have happened throughout the entire ripping process? the noise only happened a few times and it was only for a couple of seconds each time.
Post by MartyMcNuts » Fri Jun 23, 2023 9:41 pm
baneling wrote: Fri Jun 23, 2023 12:43 pm
In that case it sounds more like seeking noises, which is nothing to worry about.
baneling
Post by baneling » Fri Jun 23, 2023 10:34 pm
MartyMcNuts wrote: Fri Jun 23, 2023 9:41 pm
That can't be normal. Anyways, I put the disc on my granit countertop and saw that the disc was a little warped. Hiw does a disc warp? From heat?
Post by MartyMcNuts » Fri Jun 23, 2023 11:13 pm
baneling wrote: Fri Jun 23, 2023 10:34 pm
Yeah, heat is one cause. It's also possible it may have been warped during the pressing process.
If it is a new disc, can you return it for a replacement? Just tell them it is defective as it is slightly warped causing scraping noises during playback.
baneling
Post by baneling » Sat Jun 24, 2023 12:34 am
MartyMcNuts wrote: Fri Jun 23, 2023 11:13 pm
It's from the library
Post by Billycar11 » Sat Jun 24, 2023 1:56 am
baneling wrote: Sat Jun 24, 2023 12:34 am
ripping used discs that are damaged is a no no.
warped, stickers that unbalance it, scratches its a good way to kill a drive.
baneling
Post by baneling » Sat Jun 24, 2023 11:38 am
Billycar11 wrote: Sat Jun 24, 2023 1:56 am
Crap, I didn't know that. Thanks
Bloodpack
Post by Bloodpack » Sat Jun 24, 2023 5:55 pm
@Billycar11
just want to let you know that the ICY Box IB-525-U3 case for 5,25" optical drives works for flashing....
i flashed my LG BH16NS55 Revision: 1.02 from Oktober 2016 with the WH16NS60 1.02MK firmware.
Thank you for your work!!
