Awesome - thanks! Looks like the same arrangement for the Avatar 1 4k discjayper wrote: ↑Sun Jun 18, 2023 9:29 pmMPLS 800 has English subtitles burned in. MPLS 801 does not.rkhollister wrote: ↑Sun Jun 18, 2023 8:28 pmAnyone figure out the difference (if any) between to 2 titles on the 4K disc? I ripped both and spot checking I can't see a difference.
Avatar The Way of the Water dump submitted
Re: Avatar The Way of the Water dump submitted
My Way of Water BB SB was supported when it arrived. Thanks to those who've submitted it. My Avatar disc should be here tomorrow, hopefully.
I had to clear my DNS cache to get it to work but I was able to successfully rip Avatar The Way of Water (both 4K and 3D): https://thediscdb.com/movie/avatar-the- ... water-2022 as well as Avatar 4k: https://thediscdb.com/movie/avatar-2009 ... edition-4k. Hope this helps!
Thanks for that jayper, I watched Avatar (2009) tonight and was missing subtitles, doing all kinds of internet searches to figure out how to get them to appear since it wasn't just an unforced sub track that needed to be forced. Then I wondered if the 2nd video track I saw on the disc had it. I was in the middle of ripping that file when I read this post and it put my mind at ease.
Just wondering how big the file size is for the movie + Highest Audio (Leave the rest)?
So is 800 the correct movie title not 801
Please Advise
Louie
Please Advise
Louie
Hey all, just wanted some clarification. When you say "has English subtitles burned in" is it just for the non English dialog, or for the whole move? if it's for the non English parts, that's what I want, but not the whole movie subtitled. I'm currently ripping 8000 as it's typically the right one, so I just did it automatically since both looked identical on the blu-ray.jayper wrote: ↑Fri Jun 23, 2023 5:27 amjayper wrote: ↑Sun Jun 18, 2023 9:29 pmMPLS 800 has English subtitles burned in. MPLS 801 does not.rkhollister wrote: ↑Sun Jun 18, 2023 8:28 pmAnyone figure out the difference (if any) between to 2 titles on the 4K disc? I ripped both and spot checking I can't see a difference.
EDIT: OK, just played some of the file back on the computer, and it looks like it's only the non English has subs burned in and the English isn't turned on by default. I'm assuming then, the 8001 track didn't have the non English subs at all. Hopefully I have figured this out correctly.
Yeah, sorry. That's a good clarification.
MPLS 800 has English subs burned in for the Na'vi language. Nothing else.
MPLS 801 has no subs burned in at all.
I have a 4K copy of Avatar: The Way of Water - Ultimate Collector's Edition that's not ripping for me. Other 4K movies rip fine, as does the Blu-Ray disk that's in the set. Here's what gets displayed when I try to open the disk:
MakeMKV v1.17.4 win(x64-release) started
Using LibreDrive mode (v06.3 id=866A98CB9C4E)
Downloading latest HK to C:\Users\Peter/.MakeMKV ...
Saved AACS dump file as C:\Users\Peter/.MakeMKV/MKB20_v77_Avatar-_The_Way_of_Water_9CF2.tgz
I tried the DNS flush but it didn't help and "Enable Internet Access" is enabled. There doesn't seem to be any current information on the hostname for the HK download in the UHD FAQ but I'm getting 185.84.108.20 for hkdata.fairuse.org, and I can get to the website.
How can I get this to rip?
In case it's actually a key issue, I sent the dump file to svq@makemkv.com
Update: It's been a week and it's still giving the exact same error.
Would anyone happen to have any information on the issue I'm encountering? It's been a month and I still can't rip this video.
Thank you.
Thank you.
Hey all, this is slightly off topic for this thread, but not too far off as it still involves the AVATAR series, and if there is a better thread of this, please feel free to move it there.
I own the Extended collector's edition which has the three versions of the film on Blu-ray. I ripped the Extended version from that and everything is fine. When the first AVATAR got the 4k release, of course they also include a standard BD. For the original theatrical release of Avatar, would there be any reason to rip the new copy over my existing one, IF I decided to add the theatrical release in addition to the extended?
Just curious on thoughts, and as mentioned, even though this is an AVATAR based thread, if there is a better one for this question, please fee free to move it.
Thanks![Smile :)](./images/smilies/icon_smile.gif)
There is your problem. Makemkv needs to have Internet access enabled. View - Preferences General. Check the box.peter-a wrote: ↑Sun Jul 09, 2023 8:46 pmI have a 4K copy of Avatar: The Way of Water - Ultimate Collector's Edition that's not ripping for me. Other 4K movies rip fine, as does the Blu-Ray disk that's in the set. Here's what gets displayed when I try to open the disk:
