The Firm 4K
The Firm 4K
Typical release day issues.
Sent the tgz file up. Not sure if anyone is doing anything with them anymore.
I'm still waiting for results for John Wick, Chapter 4 and Time Bandits.
Balthazar2k4
Re: The Firm 4K
Strange, I am able to rip all of those titles. There was an HK drop over the weekend.
Re: The Firm 4K
For me, impossible to rip this disc. It seems it's impossible to decrypt
Is there any solution
Re: The Firm 4K
I have tried all three movies on multiple occasions since the purported HK drop.
My software is not allowing 4K HK files from coming through.
I have internet access turned on, and all the media work perfectly through other software.
I am at a loss as to what to do.
Re: The Firm 4K
I tried removing the private_data file, rebooted my machine.
No joy.
I am grateful for having an alternative program that DOES work.
I prefer the makemkv interface, but what good does that do me if I can't get the f'ing thing to work!
No joy.
Re: The Firm 4K
Since the outage has passed & only a few are still reporting problems, it's likely NOT the program.philb1701 wrote: Thu Jun 22, 2023 11:30 pm I tried removing the private_data file, rebooted my machine.
No joy.
Have you downloaded https://makemkv.com/sdf.bin to your MakeMKV data directory (defined in Preferences > 'General' tab), & restarted MakeMKV?
Have you reviewed steps in Fixing Volume Key is Unknown? You've appear to have already tried everything above:
Everything below this line is subject to change - hkdata.fairuse.org is no longer used!
Have you flushed the DNS cache? There are commands unique to an OS, or you could just reboot your PC (& possibly router, depending on setup). Others have reported this sorting things.
Re: The Firm 4K
It would appear that either flushing my DNS server and/or putting in the proxy address worked, since I can now rip Time Bandits 4K.
Thanks to everyone for their suggestions.
Re: The Firm 4K
I have the UK version of this movie and this version also can’t be decrypted.It does seem to be taking a long time to get the codes, Maybe it’s my imagination but I wonder if something is going on in the background . If anyone knows anything please let me know
