as cooper says i can only flash pioneers from before 12/22zaqqaz6917 wrote: Wed Jun 14, 2023 7:29 pm@ BillyBillycar11 wrote: Wed Jun 14, 2023 1:35 amworse it cant be flashed currently by the public so if the fw is after 12/2022 you cant rip uhd with it.
for now pioneers you must buy from a flasher like me marty or asmcom we can flash pioneers.
Can you flash the S13UBK as well?
zaqqaz6917
Thanks to both Cooper and Billy for the info.
ASUS BW-16D1HT does not read the disk after brushing 3.10MK firmware.
Now I can't flash back the firmware I backed up, and I'm at a loss.
Do any good people know that I can still be saved?
When I opened the it to observe its working state, I found that it seems that only the tray is still working at present ...
Does anyone happen to have the sdf.bin handy? Downloading it from the website isn't working since certificate seems to have expired.
I just registered just to say THANK YOU! I just flashed my LG BP60 drive using the SDF Flasher GUI and it seems to worked perfectly. Now to learn how to backup my UHD discs so that I can share them to my Apple TVs. Thanks again.
hey all, I have the LG BP60NB10 and ripped several discs successfully. Last night I ripped a disc and a few times it was making a buzzing sound for a few seconds. it sounded like something was touching a spinning fan or something. has anyone experienced this before?
Perhaps your disc wasn't clicked in correctly or maybe the disc is slightly warped?baneling wrote: Thu Jun 22, 2023 5:24 pm hey all, I have the LG BP60NB10 and ripped several discs successfully. Last night I ripped a disc and a few times it was making a buzzing sound for a few seconds. it sounded like something was touching a spinning fan or something. has anyone experienced this before?
I took out the disc and put it back in and made sure it was in properly. Maybe it was warped. but if it was warped, wouldn't the noise have happened throughout the entire ripping process? the noise only happened a few times and it was only for a couple of seconds each time.MartyMcNuts wrote: Fri Jun 23, 2023 3:03 amPerhaps your disc wasn't clicked in correctly or maybe the disc is slightly warped?baneling wrote: Thu Jun 22, 2023 5:24 pm hey all, I have the LG BP60NB10 and ripped several discs successfully. Last night I ripped a disc and a few times it was making a buzzing sound for a few seconds. it sounded like something was touching a spinning fan or something. has anyone experienced this before?
In that case it sounds more like seeking noises, which is nothing to worry about.baneling wrote: Fri Jun 23, 2023 12:43 pmI took out the disc and put it back in and made sure it was in properly. Maybe it was warped. but if it was warped, wouldn't the noise have happened throughout the entire ripping process? the noise only happened a few times and it was only for a couple of seconds each time.MartyMcNuts wrote: Fri Jun 23, 2023 3:03 amPerhaps your disc wasn't clicked in correctly or maybe the disc is slightly warped?baneling wrote: Thu Jun 22, 2023 5:24 pm hey all, I have the LG BP60NB10 and ripped several discs successfully. Last night I ripped a disc and a few times it was making a buzzing sound for a few seconds. it sounded like something was touching a spinning fan or something. has anyone experienced this before?
That can't be normal. Anyways, I put the disc on my granit countertop and saw that the disc was a little warped. Hiw does a disc warp? From heat?MartyMcNuts wrote: Fri Jun 23, 2023 9:41 pmIn that case it sounds more like seeking noises, which is nothing to worry about.baneling wrote: Fri Jun 23, 2023 12:43 pmI took out the disc and put it back in and made sure it was in properly. Maybe it was warped. but if it was warped, wouldn't the noise have happened throughout the entire ripping process? the noise only happened a few times and it was only for a couple of seconds each time.MartyMcNuts wrote: Fri Jun 23, 2023 3:03 am
Yeah, heat is one cause. It's also possible it may have been warped during the pressing process.baneling wrote: Fri Jun 23, 2023 10:34 pmThat can't be normal. Anyways, I put the disc on my granit countertop and saw that the disc was a little warped. Hiw does a disc warp? From heat?MartyMcNuts wrote: Fri Jun 23, 2023 9:41 pmIn that case it sounds more like seeking noises, which is nothing to worry about.baneling wrote: Fri Jun 23, 2023 12:43 pm
If it is a new disc, can you return it for a replacement? Just tell them it is defective as it is slightly warped causing scraping noises during playback.
It's from the libraryMartyMcNuts wrote: Fri Jun 23, 2023 11:13 pmIf it is a new disc, can you return it for a replacement? Just tell them it is defective as it is slightly warped causing scraping noises during playback.baneling wrote: Fri Jun 23, 2023 10:34 pmThat can't be normal. Anyways, I put the disc on my granit countertop and saw that the disc was a little warped. Hiw does a disc warp? From heat?MartyMcNuts wrote: Fri Jun 23, 2023 9:41 pm
ripping used discs that are damaged is a no no.baneling wrote: Sat Jun 24, 2023 12:34 amIt's from the libraryMartyMcNuts wrote: Fri Jun 23, 2023 11:13 pmIf it is a new disc, can you return it for a replacement? Just tell them it is defective as it is slightly warped causing scraping noises during playback.baneling wrote: Fri Jun 23, 2023 10:34 pm
warped, stickers that unbalance it, scratches its a good way to kill a drive.
Crap, I didn't know that. ThanksBillycar11 wrote: Sat Jun 24, 2023 1:56 amripping used discs that are damaged is a no no.baneling wrote: Sat Jun 24, 2023 12:34 amIt's from the libraryMartyMcNuts wrote: Fri Jun 23, 2023 11:13 pm
@Billycar11
just want to let you know that the ICY Box IB-525-U3 case for 5,25" optical drives works for flashing....
i flashed my LG BH16NS55 Revision: 1.02 from Oktober 2016 with the WH16NS60 1.02MK firmware.
Thank you for your work!!
