I enabled debugging in preferences, but I don't see "Debug logging enabled, log will be saved as C:\Users\<username}/MakeMKV_log.txt" or anything like that. Is that feature different now? Where are the debug messages logged?
* View
* Preferences
* General
* Log debug messages
Debug logs?
Re: Debug logs?
You restarted MakeMKV after turning it on, correct? The log is only started after the program restarts.
MakeMKV_log.txt should appear in your personal directory. If you are running more than one copy of MakeMKV (to rip more than one disk at a time, for example), the second copy of the file will be MakeMKV_log_1.txt, going up from there (if you have more than two drives).
stephschm
Re: Debug logs?
Location - the path contains dots !
C:\Users\userid\.MakeMKV\
Re: Debug logs?
Not necessarily - it depends on how things were set up when you installed MakeMKV. My logs are in the <userid> directory, not a "hidden" directory under that.Location - the path contains dots !
