Avatar 4K UHD can't be decrypted
Whitestar2
#1 Post by Whitestar2 » Sat Jun 17, 2023 4:15 pm
Just received both Avatar & The Way of Water 4K UHD discs. Can't Rip either: Message:
The Volume key is unknown for this disc- video can't be decrypted.
Saved AACS dump file:...MakeMKV/MKB20 v77 Avatar -The Way Of Water C2CB.tgz
Never happened before.
Do I upload these files for a solution?
Let me know,
Thank's!
audit13
Re: Avatar 4K UHD can't be decrypted
#2 Post by audit13 » Sun Jun 18, 2023 2:32 pm
Bagdad48
#3 Post by Bagdad48 » Sun Jun 18, 2023 3:03 pm
Turning on VPN did the trick for Way of Water to fetch the HK.
Geneo
#4 Post by Geneo » Wed Jun 21, 2023 11:03 pm
I had to clean the disc good and turn up the retry setting. And finally, was able to get it done.
Edit- I have the Amazon Version
Jman5150
#5 Post by Jman5150 » Thu Jun 22, 2023 5:01 am
Having issues too…Walmart edition…(are the editions different?) I just cleaned it up the retry (didn’t know it was a thing till now) and will seee….
Jman5150
#6 Post by Jman5150 » Thu Jun 22, 2023 12:15 pm
Why would a vpn help? What vpn?
Jman5150
#7 Post by Jman5150 » Thu Jun 22, 2023 12:19 pm
Can’t seem to get it work without a hash issue….this is what shows up in the windows…I abbreviated after 3 repetition…
Failed to save title /BDMV/STREAM/00108.m2ts to file /Volumes/easystore 4/avatar/AVATAR_THE_WAY_OF_WATER 4k 3/BDMV/STREAM/00108.m2ts
DEBUG: Code 0 at |kH3";cDQEq$Mk<}c:121267063
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00086.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00086.m2ts to file /Volumes/easystore 4/avatar/AVATAR_THE_WAY_OF_WATER 4k 3/BDMV/STREAM/00086.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00102.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00102.m2ts to file /Volumes/easystore 4/avatar/AVATAR_THE_WAY_OF_WATER 4k 3/BDMV/STREAM/00102.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00096.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00096.m2ts to file /Volumes/easystore 4/avatar/AVATAR_THE_WAY_OF_WATER 4k 3/BDMV/STREAM/00096.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00090.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00090.m2ts to file /Volumes/easystore 4/avatar/AVATAR_THE_WAY_OF_WATER 4k 3/BDMV/STREAM/00090.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00120.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00120.m2ts to file /Volumes/easystore 4/avatar/AVATAR_THE_WAY_OF_WATER 4k 3/BDMV/STREAM/00120.m2ts
Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00094.m2ts' at offset '0'
Failed to save title /BDMV/STREAM/00094.m2ts to file /Volumes/easystore 4/avatar/AVATAR_THE_WAY_OF_WATER 4k 3/BDMV/STREAM/00094.m2ts……………
…….Backup done but 8 files failed hash check
UEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00108.m2ts' at offset '154140672'
……Backup done but 8 files failed hash
#8 Post by SamuriHL » Thu Jun 22, 2023 1:18 pm
Those are read errors. Clean the disc or replace it.
pmardis
#9 Post by pmardis » Fri Jun 23, 2023 11:18 pm
I have the same problem with Avatar way of water with same error on Asus drive after 2 disk replacements. Since this is a 3 layer disk will it not work in these drives? I also cleaned the disk 3 times as well.
005003:0000 Failed to save title /BDMV/STREAM/00094.m2ts to file //zappiti4kdv/Zappiti_HDR_30ac5d48ac5d0a2c/4K_Movies/Video/AVATAR_THE_WAY_OF_WATER/BDMV/STREAM/00094.m2ts
001003:0020 DEBUG: Code 3221225488 at w.G,[.W,J~s[OWwzq<.Q$D1P:121262371
001003:0020 DEBUG: Code 3221225488 at spDZ-<~\bXU:/9Ia:213130559
001003:0020 DEBUG: Code 0 at MEkh#<`!>s(j0fBCR:121267063
001003:0020 DEBUG: Code 101000192 at Hu0Y6$"G%/26#v|y:121271617
001003:0020 DEBUG: Code 101000192 at spDZ-<~\bXU:/9Ia:213130559
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00119.m2ts' at offset '0'
005003:0000 Failed to save title /BDMV/STREAM/00119.m2ts to file //zappiti4kdv/Zappiti_HDR_30ac5d48ac5d0a2c/4K_Movies/Video/AVATAR_THE_WAY_OF_WATER/BDMV/STREAM/00119.m2ts
Encountered 351 unclassified errors
error=0x06052400 count=349 name=Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB
error=0xC0000010 count=1 name=OS error - The specified request is not a valid operation for the target device
error=0xC000009C count=1 name=OS error - STATUS_DEVICE_DATA_ERROR
005079:0080 Backup done but 50 files failed hash check
005082:0404 Backup done but 50 files failed hash check.
#10 Post by SamuriHL » Sat Jun 24, 2023 3:37 am
They can be difficult for sure. I use my bu40n most of the time. I have a Pioneer drive I use, as well. My Asus and lg drives are sitting on a shelf because they just don't handle triple layer very well. One thing you can try is using speed control to slow it down but that's rarely successful.
#11 Post by Coopervid » Sat Jun 24, 2023 9:33 am
If you have a friendly drive like an ASUS or LG BH16NS40 or NS55 you can flash it to official firmware BH16NS60 1.02. Firmware of official drive handles 3-layer discs better.
Jman5150
#12 Post by Jman5150 » Sat Jun 24, 2023 6:12 pm
Other disks keep saying…
Program reads data faster than it can write to disk, consider upgrading your hard drive if you see many of these messages.
It’s a good wd elements hard drive….should the above things help fix as well?
#13 Post by dcoke22 » Mon Jun 26, 2023 4:47 pm
Jman5150 wrote: Sat Jun 24, 2023 6:12 pm Other disks keep saying…
That message means what it says and isn't a problem necessarily. If you're getting that message when ripping an optical disc, then probably the storage you're writing to is slow for some reason. Maybe your spinning hard drive is nearly full or it is connected to a USB2 port or something.
ChuckEbby
#14 Post by ChuckEbby » Mon Jul 10, 2023 12:53 am
I was able to save a copy by selecting both the 800 and the 801 versions and attempting to save both titles. Trying to save one or the other wasn't working. When I tried to save both it saved one and one failed which was fine with me as I only wanted the one working copy.
This is the error(s) I was getting:
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00098.m2ts' at offset '361691136'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '361691136'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00098.m2ts' at offset '362016768'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '362016768'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00098.m2ts' at offset '362016768'
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/BDMV/STREAM/00098.m2ts' at offset '362280960'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '362280960'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00098.m2ts' at offset '362280960'
Failed to save title 1 to file G:/Video/Avatar/Avatar_t01.mkv
ChromePlanet
#15 Post by ChromePlanet » Fri Jul 14, 2023 3:08 pm
I ripped both Avatar and Way Of Water in 4K without problems.
