Not seeing Na'vi subtitles in Avatar 1 & 2 4k/bd release
Giffdev
#1 Post by Giffdev » Wed Jun 21, 2023 5:40 am
Hey folks,
sorry if this has been posted in the past related to the previous BD releases, but I recently was backing up my 4k and BD discs of the new Avatar and Avatar Way of Water and noticed the Na'vi language isn't showing up in my MKV file. Normally, this is just related to a secondary English sub track that I use MKV Tool Nix GUI to set to "forced" and I'm all good, but in these discs there only seems to be one English subtitle track and no way to display the Na'vi text. I'm sure someone has cracked this nut before, so can someone point me to a walkthrough of what's needed to see the Na'vi language?
Chetwood
Re: Not seeing Na'vi subtitles in Avatar 1 & 2 4k/bd release
#2 Post by Chetwood » Wed Jun 21, 2023 3:59 pm
Avatar 1 has been discussed to death as one example where there's actually forced items inside the subtitle stream. When you check the box for
Subtitles PGS English (forced only)
MakeMKV will rip them as an extra stream to your MKV. I would suspect the same happening with Avatar 2.
SlyMikael
#3 Post by SlyMikael » Wed Jun 21, 2023 10:40 pm
Chetwood wrote: Wed Jun 21, 2023 3:59 pm Avatar 1 has been discussed to death as one example where there's actually forced items inside the subtitle stream. When you check the box for
I'm having the same issue. After ripping, however, I can only get the Na'vi translations for other languages besides English. There was not a second subtitle stream for English on either the 4k disc or the standard bluray. However, playing back in an actual player, I did get English subs. So they're definitely on the disc, but for whatever reason I'm not seeing them.
See the below images. This scene should have a translation, but it just says "speaking Na'vi" when I try the only English subtitle option. I also tried the 2nd Spanish option, this worked fine (except it's in Spanish :cry: )
SlyMikael
#4 Post by SlyMikael » Wed Jun 21, 2023 11:38 pm
SlyMikael wrote: Wed Jun 21, 2023 10:40 pm
Follow-up. Choosing the 2nd option in makemkv resolved the issue. Make sure to choose Source File name: 00800.mpls as it looks like the segment maps are different (subs must be burned right into the video stream instead of a sub track)
Anthepioneer
#5 Post by Anthepioneer » Tue Nov 14, 2023 4:40 pm
Thanks for that VERY useful information. I often wondered why some discs have two copies of what appears to be the same film on them. And sadly you can't assume that the first file is necessarily the correct one to use. I came across a difference with Thor Ragnarok UHD BD where the title "Thor Ragnarok" (08:27) appears to have what I think is a German translation under the English title.
Anthony
Anthony
Peterborough (UK)
