Nvidia Shield Pro, UHD rip playback not always correct
Litmusdragon
Post by Litmusdragon » Mon Jun 19, 2023 6:23 pm
Hello, just recently (past month or so) I finally got a Libredrive firmware loaded onto my BR drive and have started ripping stuff in UHD. I am encountering a weird issue where some of my rips (and not just my rips, some rips I downloaded) do not play back with the correct color/brightness ratios. I am playing these back using Channels DVR software on my 2019 Nvidia Shield TV Pro. I also tested in Kodi on that same machine and the results were identical. The TV (Sony 950G) does switch into HDR mode on both the "bad" and "good" rips so they are being correctly detected as HDR, whether or not they look correct when played back. I am not sure if the issue is in my Shield TV Pro, the TV, or the rips.
Of movies I tested, the following look great:
Harry Potter (all)
LOTR (all)
2001
Toy Story 1, 2, 3
These other movies I tested look very "washed out". A grey haze appearing over the frame as though my TV is not calibrated correctly:
Lost Highway
Mulholland Drive
Pulp Fiction
Captain Marvel
Wreck it Ralph
Ralph Breaks the Internet
Ex Machina
I can spot no significant difference in the MediaInfo between a workign and non- working rip. Here are two examples:
2001: A Space Odyssey (works):
General
Unique ID                                : 15283356893159955517839694362184635130 (0xB7F77AC0E8E9706B35CD754A4BDD2FA)
Complete name                            : E:\videos\movies-4k\2001- A Space Odyssey.mkv
File size                                : 20.8 GiB
Duration                                 : 2 h 28 min
Overall bit rate                         : 20.0 Mb/s
Frame rate                               : 23.976 FPS
Movie name                               : 2001: A Space Odyssey
Encoded date                             : 2023-06-11 17:16:21 UTC
Writing application                      : HandBrake 1.6.1 2023012300
Writing library                          : Lavf59.27.100
ErrorDetectionType                       : Per level 1
Video
Format profile                           : Main 10@L5@Main
HDR format                               : SMPTE ST 2086, HDR10 compatible
Height                                   : 1 744 pixels
Display aspect ratio                     : 2.2:1
Chroma subsampling                       : 4:2:0
Mastering display color primaries        : BT.2020
Mastering display luminance              : min: 0.0050 cd/m2, max: 1000 cd/m2
Maximum Content Light Level              : 992
Maximum Frame-Average Light Level        : 282
Audio
Format                                   : DTS XLL
Commercial name                          : DTS-HD Master Audio
Channel layout                           : C L R Ls Rs LFE
Bit depth                                : 16 bits
Text
Format                                   : PGS
Codec ID                                 : S_HDMV/PGS
Codec ID/Info                            : Picture based subtitle format used on BDs/HD-DVDs
Duration                                 : 2 h 24 min
Menu
00:00:00.000                             : Chapter 1
00:02:55.634                             : Chapter 2
00:04:37.235                             : Chapter 3
00:11:37.864                             : Chapter 4
00:16:55.890                             : Chapter 5
00:19:50.940                             : Chapter 6
00:25:27.401                             : Chapter 7
00:27:35.863                             : Chapter 8
00:29:27.557                             : Chapter 9
00:33:44.481                             : Chapter 10
00:41:06.965                             : Chapter 11
00:45:35.524                             : Chapter 12
00:50:54.969                             : Chapter 13
00:54:39.610                             : Chapter 14
00:58:31.633                             : Chapter 15
01:03:53.747                             : Chapter 16
01:06:03.001                             : Chapter 17
01:12:08.241                             : Chapter 18
01:18:49.642                             : Chapter 19
01:22:59.433                             : Chapter 20
01:26:59.840                             : Chapter 21
01:27:47.471                             : Chapter 22
01:30:06.026                             : Chapter 23
01:32:48.730                             : Chapter 24
01:38:33.116                             : Chapter 25
01:40:44.830                             : Chapter 26
01:45:33.577                             : Chapter 27
01:49:39.448                             : Chapter 28
01:55:17.702                             : Chapter 29
01:57:04.226                             : Chapter 30
02:01:26.070                             : Chapter 31
02:11:31.425                             : Chapter 32
02:17:55.476                             : Chapter 33
02:20:31.632                             : Chapter 34
Wreck-It Ralph (looks bad):
General
Unique ID                                : 180931159458389594485498895561848097490 (0x881E12E3BA803B5286D84981ECAD8AD2)
Complete name                            : G:\movies\movies-1080p\Wreck-It Ralph.mkv
File size                                : 8.98 GiB
Duration                                 : 1 h 41 min
Overall bit rate                         : 12.7 Mb/s
Movie name                               : Wreck-It Ralph
Encoded date                             : 2023-06-12 17:51:12 UTC
Video
Height                                   : 1 608 pixels
Display aspect ratio                     : 2.40:1
Audio
Maximum bit rate                         : 5 742 kb/s
Number of dynamic objects                : 13
Text #1
Format                                   : PGS
Duration                                 : 1 h 40 min
Text #2
Format                                   : PGS
Duration                                 : 1 h 33 min
Menu
00:07:12.891                             : Chapter 2
00:16:35.745                             : Chapter 3
00:27:07.960                             : Chapter 4
00:37:26.578                             : Chapter 5
00:44:47.727                             : Chapter 6
00:48:45.965                             : Chapter 7
00:51:36.719                             : Chapter 8
00:58:56.867                             : Chapter 9
01:09:08.603                             : Chapter 10
01:13:40.166                             : Chapter 11
01:15:57.845                             : Chapter 12
01:18:54.021                             : Chapter 13
01:21:54.785                             : Chapter 14
01:27:26.408                             : Chapter 15
01:33:11.044                             : Chapter 16
One other weird thing to throw in here, as I undersatnd it MakeMKV should support DolbyVision is it's rips now, however Pulp Fiction (which does say Dolby Vision on the disk) does not say Dolby Vision in the MediaInfo:
General
Unique ID                                : 180667631140741528042331123846645210004 (0x87EB51F0BBAF0907BA3488CA9D5ADB94)
Complete name                            : E:\videos\movies-4k\Pulp Fiction.mkv
File size                                : 25.4 GiB
Duration                                 : 2 h 34 min
Overall bit rate                         : 23.5 Mb/s
Movie name                               : Pulp Fiction
Encoded date                             : 2023-06-12 16:13:59 UTC
Video
Height                                   : 1 632 pixels
Display aspect ratio                     : 2.35:1
Maximum Content Light Level              : 1000
Maximum Frame-Average Light Level        : 184
Audio
Format                                   : DTS XLL
Text #1
Format                                   : PGS
Duration                                 : 2 h 29 min
Text #2
Format                                   : PGS
Text #3
Format                                   : PGS
Menu
00:07:05.467                             : Chapter 2
00:14:24.530                             : Chapter 3
00:21:06.891                             : Chapter 4
00:31:21.088                             : Chapter 5
00:34:10.799                             : Chapter 6
00:49:56.494                             : Chapter 7
00:54:48.243                             : Chapter 8
01:03:30.473                             : Chapter 9
01:14:52.238                             : Chapter 10
01:22:38.287                             : Chapter 11
01:33:52.544                             : Chapter 12
01:37:40.063                             : Chapter 13
01:49:15.007                             : Chapter 14
01:55:10.737                             : Chapter 15
02:13:21.202                             : Chapter 16
Anyone know what is happening here? Thanks for any insight
AngryVirginian
Re: Nvidia Shield Pro, UHD rip playback not always correct
Post by AngryVirginian » Tue Jun 20, 2023 12:43 am
These were all custom encoded and not pure rips. What happened when you play the remux version?
Litmusdragon
Post by Litmusdragon » Tue Jun 20, 2023 4:46 am
AngryVirginian wrote: Tue Jun 20, 2023 12:43 am These were all custom encoded and not pure rips. What happened when you play the remux version?
Are you saying that running the file through Handbrake may have intoduced the problem? I hadn't considered that. I'll try playing the MakeMKV rip (no Handbrake) and see if I get a different result
Litmusdragon
Post by Litmusdragon » Tue Jun 20, 2023 2:04 pm
Re-ripped Wretch-It Ralph this morning. Tried playing the rip both on Channels DVR and Kodi.
Channels DVR- RIp does not play beyond the first second or two, screen becomes garbled. (I assume this is a Channels DVR issue)
Kodi- Rip plays, but has the same washed out colors that the version I ran through Handbrake had.
Here's the MediaInfo from the rip. The HDR info seems to be the same between this and the version I ran through Handbrake:
General
Unique ID                                : 192599370197345528514496748327681919704 (0x90E54A184D4F9DEF635212DD20080AD8)
Complete name                            : E:\videos\movies-uncompressed\Wreck-It Ralph.mkv
Format version                           : Version 2
File size                                : 39.3 GiB
Overall bit rate                         : 55.5 Mb/s
Encoded date                             : 2023-06-20 12:52:02 UTC
Writing application                      : MakeMKV v1.17.3 win(x64-release)
Writing library                          : libmakemkv v1.17.3 (1.3.10/1.5.2) win(x64-release)
Video
ID in the original source medium         : 4113 (0x1011)
Bit rate                                 : 49.2 Mb/s
Bits/(Pixel*Frame)                       : 0.248
Stream size                              : 34.8 GiB (89%)
Writing library                          : ATEME Titan File 3.8.16 (4.8.16.0)
Audio #1
Bit rate                                 : 4 598 kb/s
Stream size                              : 3.25 GiB (8%)
Audio #2
Codec ID                                 : A_AC3
Stream size                              : 463 MiB (1%)
Audio #3
ID in the original source medium         : 4353 (0x1101)
Codec ID                                 : A_AC3
Audio #4
ID in the original source medium         : 4354 (0x1102)
Codec ID                                 : A_AC3
Bit rate                                 : 320 kb/s
Channel(s)                               : 2 channels
Channel layout                           : L R
Stream size                              : 232 MiB (0%)
Title                                    : Stereo
Text #1
ID in the original source medium         : 4768 (0x12A0)
Format                                   : PGS
Bit rate                                 : 47.5 kb/s
Frame rate                               : 0.623 FPS
Count of elements                        : 3748
Stream size                              : 34.0 MiB (0%)
Text #2
ID in the original source medium         : 4769 (0x12A1)
Format                                   : PGS
Duration                                 : 1 h 32 min
Bit rate                                 : 41.8 kb/s
Frame rate                               : 0.540 FPS
Count of elements                        : 2989
Stream size                              : 27.6 MiB (0%)
Menu
00:00:00.000                             : en:Chapter 01
00:07:12.890                             : en:Chapter 02
00:16:35.744                             : en:Chapter 03
00:27:07.959                             : en:Chapter 04
00:37:26.577                             : en:Chapter 05
00:44:47.518                             : en:Chapter 06
00:48:45.964                             : en:Chapter 07
00:51:36.510                             : en:Chapter 08
00:58:56.866                             : en:Chapter 09
01:09:08.561                             : en:Chapter 10
01:13:40.165                             : en:Chapter 11
01:15:57.636                             : en:Chapter 12
01:18:53.812                             : en:Chapter 13
01:21:54.576                             : en:Chapter 14
01:27:26.199                             : en:Chapter 15
01:33:11.043                             : en:Chapter 16
Based on this result, I do not believe issue is due to Handbrake.
Balthazar2k4
Post by Balthazar2k4 » Tue Jun 20, 2023 3:04 pm
Yes, Handbrake is the culprit. It does not support proper HDR10 workflow or DV at all.
Post by dcoke22 » Tue Jun 20, 2023 3:29 pm
Balthazar2k4 wrote: Tue Jun 20, 2023 3:04 pm Yes, Handbrake is the culprit. It does not support proper HDR10 workflow or DV at all.
Is that still true? I was under the impression that recent versions of Handbrake did handle HDR10 properly, although it does not handle HDR10+ or Dolby Vision.
https://handbrake.fr/docs/en/1.6.0/technical/hdr10.html
Balthazar2k4
Post by Balthazar2k4 » Tue Jun 20, 2023 9:09 pm
Yeah, sorry, I forgot they finally upgraded the pipeline to 10-bit. Still doesn't pass dynamic metadata though.
Litmusdragon
Post by Litmusdragon » Wed Jun 21, 2023 12:25 am
Maybe I should ask this question, does anyone successfully use an Nvidia Shield to play back HDR MakeMkv rips (without washed out colors)? If so what app do you use?
Whatever this issue is, it isn't a Handbrake thing, the same issue happened with the full sized rip
Krawk
Post by Krawk » Wed Jun 21, 2023 12:39 am
I have not tried my Shield Pro for HDR or DV content. I am hoping it works!
King_theNorth
Post by King_theNorth » Wed Jun 21, 2023 2:16 am
I use a Nvidia Shield Pro to play back all of my bluray and 4k bluray rips. If you are wanting dolby vision, you have to make sure you have the 2019 or 2020 revision for that file. I use jellyfin and plex to play media from my local computer, and everything works good that way. The only thing to know about the shield is that dolby vision will play, but as a minimum enhancement layer: that means the tv will switch into the dolby vision mode, and have some dynamic metadata, but may not have as drastic a change from the HDR10 version compared to forcing both on a local high-end bluray player. There is still a difference, but it is not as pronounced. Hopefully they launch a shield tv with an updated processor that supports more codecs and better dolby soon, but I am not holding my breath. To make sure your rips show the proper colors and everything, you cannot use handbrake to transcode/remux your rips. You will not have the same quality. I toss the makemkv produced files straight onto my server, and both plex and jellyfin have no problem playing them to my local or remote devices. So I hope this helps. Would say the color things you have talked about are because while handbrake does support 10 bit color, it may still not fully support hdr10/dolby vision disks due to the way bluray disks encode their HDR streams. It may just assume the 10 bit color is in a SDR format, and that is why it is washed out.
Balthazar2k4
Post by Balthazar2k4 » Wed Jun 21, 2023 4:11 am
I use a 2019 Shield TV Pro and it works with my DV and HDR10 rips just fine. I do have to massage the DV titles by dumping the enhancement layer, but they do engage the DV mode on my TV. I am using Plex.
quietvoid
Post by quietvoid » Wed Jun 21, 2023 11:17 am
Balthazar2k4 wrote: Tue Jun 20, 2023 9:09 pm Yeah, sorry, I forgot they finally upgraded the pipeline to 10-bit. Still doesn't pass dynamic metadata though.
FYI Handbrake 1.7 does support both HDR10+ and Dolby Vision encoding.
https://github.com/HandBrake/HandBrake/ ... ndbrake-17
Balthazar2k4
Post by Balthazar2k4 » Wed Jun 21, 2023 12:47 pm
quietvoid wrote: Wed Jun 21, 2023 11:17 am
LOL. Clearly everyone should just ignore me. I stopped encoding a year or so ago so I am evidently out of date and should stay quiet on the subject. Sorry for the confusion everyone.
WEZZEBE
Post by WEZZEBE » Wed Jul 05, 2023 12:08 pm
King_theNorth wrote: Wed Jun 21, 2023 2:16 am I use a Nvidia Shield Pro to play back all of my bluray and 4k bluray rips. If you are wanting dolby vision, you have to make sure you have the 2019 or 2020 revision for that file. I use jellyfin and plex to play media from my local computer, and everything works good that way. The only thing to know about the shield is that dolby vision will play, but as a minimum enhancement layer: that means the tv will switch into the dolby vision mode, and have some dynamic metadata, but may not have as drastic a change from the HDR10 version compared to forcing both on a local high-end bluray player. There is still a difference, but it is not as pronounced. Hopefully they launch a shield tv with an updated processor that supports more codecs and better dolby soon, but I am not holding my breath. To make sure your rips show the proper colors and everything, you cannot use handbrake to transcode/remux your rips. You will not have the same quality. I toss the makemkv produced files straight onto my server, and both plex and jellyfin have no problem playing them to my local or remote devices. So I hope this helps. Would say the color things you have talked about are because while handbrake does support 10 bit color, it may still not fully support hdr10/dolby vision disks due to the way bluray disks encode their HDR streams. It may just assume the 10 bit color is in a SDR format, and that is why it is washed out.
So can you explain how this works in general:
1- How to set up plex on the NAS
Any special settings i need to turn on or off so DV will work
Can i select only 1 map i want (only the 4K Map i have on the NAS) ?
2- What type of Rip i need from MakeMKV
Normal Rip (In expert mode) -> Just the Movie + audio & Subs i like (Mkv-File)
Or the full Backup Rip?
I would prefer The simple Mkv-file, but not sure if that 1 layer DV will work well vs the 2 layer DV from the disk?
3- Setup Plex on Shield Pro 2019-2020
This i can find myself so no need there unless you have an important remark there.
Is the DV really that small a difference on the Shield true Plex?
And do you know of any ways that a USB local file on the Shield (or any other divice) will give DV?
Still looking for what upgrade i want over my older Nvidia Shield 2015 or 2017.
Seems the Zidoo Z9X PRO (July 2023) still can't do those DV-decodings (FEL stuff)
WEZZEBE
Post by WEZZEBE » Wed Jul 05, 2023 12:20 pm
I also have some rips (which does say Dolby Vision on the disk) that does not say Dolby Vision in the MediaInfo
Like will it sometimes have DV without saying Dolby vision v....?
I will still say: SMPTE ST 2086, HDR10 compatible or so?
