It works perfectly for me with W11 b22621.1848Mrmorrison wrote: ↑Sun Jun 18, 2023 1:00 amHi everyone. I recently bought a new PC with Windows 11. To my surprise I found that drag and drop on the command prompt doesn't work and as a result I can't use the script at all. Has anyone encountered this problem and solved it?
Ugoos AM6B Plus | Remote control G20S PRO Plus | Splitter HDMI HDFury AVR-KEY | Display LG 65B6V | Cables HDMI KabelDirekt Pro series | Audio processor Yamaha RX-V775 | Rotel RMB-1075 | Storage Qnap Ts-431K +TL-D800C |
My PC Ryzen 7950X
My PC Ryzen 7950X
Works fine for me on Win 11Mrmorrison wrote: ↑Sun Jun 18, 2023 1:00 amHi everyone. I recently bought a new PC with Windows 11. To my surprise I found that drag and drop on the command prompt doesn't work and as a result I can't use the script at all. Has anyone encountered this problem and solved it?
Thanks everyone for your feedback. I don't understand why my prompt behaves like this. Then it opens only with administrator permissions.
NO! launch it normally without administrator permissions.Mrmorrison wrote: ↑Sun Jun 18, 2023 9:57 amThanks everyone for your feedback. I don't understand why my prompt behaves like this. Then it opens only with administrator permissions.
Otherwise, you can't drag & drop
My PC Ryzen 7950X
My PC Ryzen 7950X
Unfortunately I can't do it. However I open it, it always opens with administrator permissions. By default... I've always been used to using "open as administrator" for this thing. Now it opens in this mode automatically and I'm afraid that's why I can't drag and dropdom61 wrote: ↑Sun Jun 18, 2023 10:01 amNO! launch it normally without administrator permissions.Mrmorrison wrote: ↑Sun Jun 18, 2023 9:57 amThanks everyone for your feedback. I don't understand why my prompt behaves like this. Then it opens only with administrator permissions.
Resolved! I don't know why but the user account settings were changed to the lowest point.
https://github.com/HerMajestyDrMona/Win ... TaskbarFixMrmorrison wrote: ↑Sun Jun 18, 2023 1:00 amHi everyone. I recently bought a new PC with Windows 11. To my surprise I found that drag and drop on the command prompt doesn't work and as a result I can't use the script at all. Has anyone encountered this problem and solved it?
mmm Same issues since the latest Win11 update...Mrmorrison wrote: ↑Sun Jun 18, 2023 10:28 amResolved! I don't know why but the user account settings were changed to the lowest point.
Changing the account settings did not work for me.
EDIT: had to reboot.
I'm happy to have helped you!RESET_9999 wrote: ↑Mon Jun 19, 2023 5:51 pmmmm Same issues since the latest Win11 update...Mrmorrison wrote: ↑Sun Jun 18, 2023 10:28 amResolved! I don't know why but the user account settings were changed to the lowest point.
Very interesting. I never knew extracting the RPU and injecting it in to a remux was a lossy progress. I thought it truly was the best of both worlds. It seems P5 DV is still absolute best, as it's in the IPTPQc2 colour space and includes both chroma and luma mapping; it's just lacking the bit rate of a Blu-ray.quietvoid wrote: ↑Fri Jun 09, 2023 11:37 amYes, the mapping metadata contained in profile 5 is not usable in profile 8.1.Trees wrote: ↑Thu Jun 08, 2023 8:25 pmQuick question, when using dovi_tool mode 3 to extract the RPU from a P5 file, is any from the RPU data lost? I'm asking because the other day, I read someone claiming both chroma and luma data being lost when using mode 3; apparently, only dynamic metadata is being carried over from the P5 files to the P8.1 files.
Is this true? Just curious.
It wouldn't make sense to keep it.
Which begs the next question; seeing as the IPTPQc2 has been reverse engineered by gifted folk, as it can be decoded by MPV to be properlt played back, is it possible to convert the Blu-ray high bit-rate stream to the IPTPQc2 colour space and inject the lossless RPU to truly get best of both worlds?
Why do you believe the metadata is any better for quality? It's literally only required to decode the colours into regular PQ/BT.2020.Trees wrote: ↑Tue Jun 20, 2023 9:10 amVery interesting. I never knew extracting the RPU and injecting it in to a remux was a lossy progress. I thought it truly was the best of both worlds. It seems P5 DV is still absolute best, as it's in the IPTPQc2 colour space and includes both chroma and luma mapping; it's just lacking the bit rate of a Blu-ray.
It doesn't improve the quality at all on playback. The process is only lossy in that it loses the original metadata, the quality is unaffected.
And any reencoding of a Blu-ray into IPT would be worse as transcoding is lossy.
Good afternoon, tell me what sequence of script points you need to use to analyze the finished mkv file, you need to get a screenshot similar to what is created automatically when converting HDR10+ to DV, is it possible? I can't find a similar scenario, thank you
To plot DV (graph screenshot), the workflow is 6-2-4.TheEqualizer wrote: ↑Tue Jun 20, 2023 1:40 pmGood afternoon, tell me what sequence of script points you need to use to analyze the finished mkv file, you need to get a screenshot similar to what is created automatically when converting HDR10+ to DV, is it possible? I can't find a similar scenario, thank you
For just a quick info summary about the RPU metadata in any file: 2-3
to check the metadata of any frame, input an RPU in: 2-3 or 2-2
Thank you very muchRESET_9999 wrote: ↑Tue Jun 20, 2023 2:03 pm
Excellent answer thxquietvoid wrote: ↑Tue Jun 20, 2023 11:13 amWhy do you believe the metadata is any better for quality? It's literally only required to decode the colours into regular PQ/BT.2020.Trees wrote: ↑Tue Jun 20, 2023 9:10 amVery interesting. I never knew extracting the RPU and injecting it in to a remux was a lossy progress. I thought it truly was the best of both worlds. It seems P5 DV is still absolute best, as it's in the IPTPQc2 colour space and includes both chroma and luma mapping; it's just lacking the bit rate of a Blu-ray.
