The Hobbit Battle of five armies 3D
Everything related to Blu-ray 3D and 3D MKV files
Shamoo
#1 Post by Shamoo » Sun Sep 25, 2016 8:38 pm
hi all, i've been trying to back up The Hobbit 3 in 3D for a while but no success. it has 3 files the same, i've tried everyone but have the same error, ive also tried different programs but still no joy.
i've just update to the latest version and same error. has anyone over come this?
MakeMKV v1.10.2 win(x64-release) started
File 00962.mpls was added as title #0
Title #00005.mpls has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00000.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00007.mpls was added as title #1
Title #00201.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00205.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00199.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00206.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00207.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00208.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00202.mpls has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00120.mpls(1) has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.mpls has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00121.mpls(1) has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00100.mpls was added as title #2
File 00101.mpls was added as title #3
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00017.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00018.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00019.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00020.m2ts has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00026.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00028.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00029.m2ts has length of 1 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00030.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00036.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.m2ts has length of 15 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00047.m2ts was added as title #4
Title #00048.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00055.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00057.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00059.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00061.m2ts has length of 19 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 37 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Saving 1 titles into directory C:/Users/User/Desktop
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '4078909440'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '4083154944'
Error 'Scsi error - NOT READY:LOGICAL UNIT NOT READY, OPERATION IN PROGRESS' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '4083154944'
Error 'Scsi error - MEDIUM ERROR:READ RETRIES EXHAUSTED' occurred while reading '/BDMV/STREAM/00006.m2ts' at offset '4083154944'
Failed to save title 0 to file C:/Users/User/Desktop/The_Hobbit_The_Battle_of_the_Five_Armies_Part_1_t00.mkv
0 titles saved, 1 failed
Re: The Hobbit Battle of five armies 3D
#2 Post by Woodstock » Sun Sep 25, 2016 8:55 pm
Start here: http://makemkv.com/forum2/viewtopic.php?f=8&t=15055
Most likely cause is a "dirty" disk.
3DCBD
#3 Post by 3DCBD » Mon Jun 19, 2023 7:15 pm
I can't get disc one of the first hobbit to rip, so it must be something with these discs.
Radiocomms237
#4 Post by Radiocomms237 » Mon Jun 19, 2023 10:22 pm
No problems with mine, I ripped Five Armies blu-ray 2D (theatrical & extended) & 3D (extended only) with no errors.
As above, you can try cleaning the disc, or try it in a different drive, or if all else fails you may need to replace it?
