How to know if my firmware is encrypted
Korvenwin
Post by Korvenwin »
I've just bought an Archon MD-8107U3YC.
In my case the drive information is:
Product: BD-RE BU40N
Revision: 1.02
Bus encryption flags: 1F
How can I know if it is an encrypted firmware to flash with the right method?
Re: How to know if my firmware is encrypted
It's encrypted
Anything in 2020 is
LG pulled an Asus 3.02 reuse old firmware name but now encrypted
Korvenwin
Post by Korvenwin »
Thank you very much Billycar11. That was why the Marty's SDFtool didn't work. It detects my unit as not encrypted and in fact it does.
One last question:
After reading a few post about v1.03MK vs v1.0DE, I'm not sure witch firmware to choose. I don't think I will use DVDFab.
Which one do you recommend me?
Korvenwin wrote:
Mon Jan 10, 2022 5:30 pm
One last question:
If you have SDFtool Flasher v1.3.1 and the encypted firmware detection is incorrect, simply click on the ✔ or ✖ to toggle it.
Korvenwin
Post by Korvenwin »
MartyMcNuts wrote:
Mon Jan 10, 2022 8:51 pm
Yes, that was what I did and it was correctly flashed. THANK YOU VERY MUCH for your work.
ErickKing wrote:
Fri May 13, 2022 9:31 am
Hello guys, im sorry for bumping old thread, just searching similar information for my issue. Can someone help me pleaes?
by reading the guide it has a list
quick hack is if the drive firmware date is after 2020 its probably encrypted
but guide linked below
IPFighter
Post by IPFighter »
I have the same question, and a follow up. Just purchased an LG14NS40 and want to set it up to use with MakeMKV for Blu-Rays and 4k ripping to Plex. Was trying to follow the 2019 video/post to flash down to 1.02, but was not sure if I should follow encrypted instructions or non-encrypted instructions. I have attached screenshot of MakeMKV info, namely:
USE THIS?: 3. If you have a listed encrypted firmware you must use this command: makemkvcon64.exe f --all-yes -d “ your drive letter here Example: D”: rawflash enc -i “path to your firmware Example: C:\Users\Billy\Downloads\Downgrade-Enabled-Firmware\Auto-Flash\LG-Desktop-NS60-sleep-fix\WH16NS60-1.02-MK.bin”
OR USE THIS?: 4. If you have unencrypted firmware use this command: makemkvcon64.exe f --all-yes -d “ your drive letter here Example: D”: rawflash -i “path to your firmware Example: C:\Users\Billy\Downloads\Downgrade-Enabled-Firmware\Auto-Flash\LG-Desktop-NS60-sleep-fix\WH16NS60-1.02-MK.bin”
Also, confused about what flasher to use. I have the LG14 not the LG16, but can I use the same file? Your instructions and video use "WH16NS60-1.02-MK.bin", but in the all you need firmware pack it downloaded something different (unless I grabbed the wrong one): HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin.
IPFighter wrote:
Mon Jun 19, 2023 5:14 pm
See guide below you likely have encrypted fw but check the known encrypted fw list first to be sure.
Yes you flash a wh14ns40 to WH16NS60
IPFighter
Post by IPFighter »
Many thanks for the quick reply, and sorry for the obtuse questions. Yes, I have read the links but still have some confusion.
First, you thought my firmware was encrypted but that I should check. I looked at your list, and found this:
HL-DT-ST-BD-RE_WH14NS40-NS50-1.05-N000900-212005061444.bin
This appears to be my LGWH14NS40 drive, 1.05, see below from MakeMKV, and I assume that the added N000900 is just superfluous, but wanted to make sure.
Product: BD-RE WH14NS40
Revision: 1.05
Serial number: KLZM8AF4753
Highest AACS version: 25
Assuming my drive is encrypted, this is the firmware I downloaded from your site, which currently sits in my Download folder:
E:\DownloadDir\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
If I understand the instructions, assuming my LG drive is assigned D: in Windows 11, at the command prompt in the PS C:\Programs Files (x86)\MakeMKV directory I would type the following:
makemkvcon64.exe f --all-yes -d D: rawflash enc -i E:\DownloadDir\HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin
Part of my question is to confirm that I should be using this firmware file (HL-DT-ST-BD-RE_WH16NS60-1.02-NM00100-211810291936.bin) even though your example shows to use this firmware file (WH16NS60-1.02-MK.bin). In other words, why are the files named differently? Are they the same file, and the added verbiage in teh same is superfluous? Or do I need to find the file specifically named: WH16NS60-1.02-MK.bin? I have downloaded the mk-firmware-pack-20200720 and in the Old folder I do not see the specific file WH16NS60-1.02-MK.bin, which you indicated that I should use with my LG14NS40
Thank you
IPFighter wrote:
Mon Jun 19, 2023 7:30 pm
Revision: 1.05
Thank you
If it the one in the all you need fw pack it's the right one
