Is my Buffalo drive dying?
Stryker412
Post by Stryker412 » Sun Jun 18, 2023 4:53 pm
Lately I've noticed VERY slow transfer speeds from my Buffalo BU10 which I have not had in the past. What is going on?
Re: Is my Buffalo drive dying?
Post by Billycar11 » Sun Jun 18, 2023 7:13 pm
3 things are the usual cause for this but it could be a lot more.
Dirty or bad disc clean the disc with a damp lint free microfiber cloth and dry with another.
Dirty laser clean the lasers in the drive same way to clean a disc.
This can also be caused by the drive not getting enough power is the light on top red at any time?
Stryker412
Post by Stryker412 » Sun Jun 18, 2023 10:29 pm
1. These have been brand new discs. (not to say they can't be dirty but generally they are clean)
2. Will try that
3. No, never red. Although are there any Y adapters I can use to power the drive but use the back ports of my tower?
Post by Billycar11 » Sun Jun 18, 2023 10:36 pm
Please this has been said 1000 times it don't matter if it's new if the discs give you trouble and you don't have another drive you clean the disc
