John Wick 4
ionblue
Re: John Wick 4
#61 Post by ionblue » Sun Jun 18, 2023 2:45 am
MSCloude115 wrote: Sat Jun 17, 2023 5:57 pm
ionblue wrote: Sat Jun 17, 2023 5:36 pm Now I'm just starting to lose my patience. It's been a full week since I sent the first dump and 4 days later sent it again.
MakeMKV v1.17.4 darwin(arm64-release) started
Optical drive "BD-RE ASUS BW-16D1HT 3.10 KLUJ5MD3517d" opened in OS access mode.
Using LibreDrive mode (v06.3 id=0FA242DD4D0B)
Saved AACS dump file as ***/Library/MakeMKV/MKB20_v77_John_Wick-_Chapter_4_51AE.tgz
Mike stated that while the site and forum are up and running the keys are not and I’m positive he will update when it is. The rest of us are waiting as well so we are gonna have to have patience.
I’m trying. Starting to think my hk file isn't getting updated. I get the same info if internet access is on or off. What/where is that file on Mac if I want to try and brute force this thing?
Resurface9634
Re: John Wick 4
#62 Post by Resurface9634 » Sun Jun 18, 2023 3:27 am
My 2 disk from amazon is working now. THANK YOU! :D
ionblue
Re: John Wick 4
#63 Post by ionblue » Sun Jun 18, 2023 2:36 pm
I removed the _private_data file and tried again. This time it downloaded the latest and I'm happily ripping away. Thanks Mike.
ionblue
Re: John Wick 4
#64 Post by ionblue » Sun Jun 18, 2023 3:20 pm
Ha ha ha.... I have to laugh cause after all that patience (or not) I have a bad disk. 2 drives, same failure pretty early on and the disc is clean as a whistle. Oh well. At least I'll be able to "try" to rip the next one when it arrives.
brett1958
Re: John Wick 4
#65 Post by brett1958 » Sun Jun 18, 2023 5:56 pm
broken then it not... thank you for the update
ionblue
Re: John Wick 4
#66 Post by ionblue » Mon Jun 19, 2023 11:05 pm
2nd copy was good... even though it literally had a palm print on the backside. Definitely the worst disc I've bought over the years. And that's saying something! :D Good wiping did the trick. Just glad it actually ripped this round.
Auss1e.mkv
Re: John Wick 4
#67 Post by Auss1e.mkv » Wed Jun 21, 2023 2:19 am
Wasn't able to rip the Aussie 4K release from StudioCanal, which is just a clone of the U.S disc with the Lionsgate logo on there and everything. Maybe different keys for the pressings they did for international distributors. Sent in my dump.
File name: MKB20_v77_John_Wick-_Chapter_4_D002.tgz
DrWalrus
Re: John Wick 4
#68 Post by DrWalrus » Wed Jun 21, 2023 1:01 pm
Also failing to rip the Aussie 4k steelbook, I've submitted my dump file too: MKB20_v77_John_Wick-_Chapter_4_D002.tgz. hopefully turn around on this is quick. looking forward to adding this to my collection
Auss1e.mkv
Re: John Wick 4
#69 Post by Auss1e.mkv » Thu Jun 22, 2023 12:11 am
DrWalrus wrote: Wed Jun 21, 2023 1:01 pm Also failing to rip the Aussie 4k steelbook, I've submitted my dump file too: MKB20_v77_John_Wick-_Chapter_4_D002.tgz. hopefully turn around on this is quick. looking forward to adding this to my collection
I've just been able to open my Aussie 4K disc! Same D002 dump file as you. Try it again and make sure your MakeMKV downloads the new HK file :)
Re: John Wick 4
#70 Post by MartyMcNuts » Thu Jun 22, 2023 4:12 am
Yep, I just picked up the Aussie Steel book from JB Hi-fi and is currently ripping!
matttowns509
Re: John Wick 4
#71 Post by matttowns509 » Sun Jul 09, 2023 7:05 pm
So I was able to rip the movie. I got it from Amazon, watched it last night. Noticed this morning when I woke up to go back and check out a couple of scenes there were only two chapters. I happened to have just ripped the entire disc so I replaced it with the other of the same size into the folder and same deal. Only two chapters.
I am such a n00b at all of this I don't even know how to articulate what I am seeing and I don't know where to start looking. Can I get a little (big) nudge in the right direction?
Thank you!
-matt.
goodavis
Re: John Wick 4
#72 Post by goodavis » Sun Jul 16, 2023 3:16 pm
Hello Mine also will not rip
MKB20_v77_John_Wick-_Chapter_4_0426.tgz
Re: John Wick 4
#73 Post by MartyMcNuts » Sun Jul 16, 2023 11:13 pm
matttowns509 wrote: Sun Jul 09, 2023 7:05 pm So I was able to rip the movie. I got it from Amazon, watched it last night. Noticed this morning when I woke up to go back and check out a couple of scenes there were only two chapters. I happened to have just ripped the entire disc so I replaced it with the other of the same size into the folder and same deal. Only two chapters.
Thank you!
-matt.
Matt, in MakeMKV you should see that 00800.mpls (FPL_MainFeature) is the playlist you want and it contains 16 chapters.
matttowns509
Re: John Wick 4
#74 Post by matttowns509 » Tue Jul 18, 2023 1:49 pm
Hi Marty, thank you, I'll go look! :D
matttowns509
Re: John Wick 4
#75 Post by matttowns509 » Wed Jul 19, 2023 3:04 pm
MartyMcNuts wrote: Sun Jul 16, 2023 11:13 pm
Thank you!
-matt.
Thanks McNuts, I'm good!
